12-14-2015, 09:49 PM - 1 Like   #16
TroutHunterJohn's Avatar
The k3ii will focus better in low light than your k5, but it has more noise at high iso... in my experience
12-14-2015, 10:00 PM   #17
QuoteOriginally posted by TroutHunterJohn Quote
This is good to know! Thanks so much! I have been curious about the high ISO noise on the K-3 (ii) compared to the K-5. Thanks so much for chiming in!
12-15-2015, 02:23 AM - 1 Like   #18
PEG Moderator
Kerrowdown's Avatar
I've in the past always gone for glass, bodies can come and go, but glass is forever, well it is with Pentax backwards compatibility.
12-15-2015, 02:33 AM - 1 Like   #19
Sandy Hancock's Avatar
A pro photographer will get better results than either.
12-15-2015, 05:10 AM - 1 Like   #20
audiobomber's Avatar
DXOMark shows the same signal-to-noise ratio when compared at the same resolution and/or the same print size. There are a couple of errors people make in comparing K-3 and K-5 files:
  1. viewing on a computer at pixel level, which is unfair to the higher megapixel camera
  2. K-5 family have non-optional noise reduction at ISO's above 1600
For a valid comparison, print both at the same size or view both at 16mp resolution. Add NR to the K-3 file if ISO is greater than ISO 1600. Noise will balance out.
There are several advantages of the K-3 over the K-5
  • higher resolution with any lens
  • AF tracking controls
  • 27 AF points
  • three f/2.8-sensitive focal points
  • -3EV AF and metering
  • dual card slots
  • reliable bounce flash
  • superior rear panel LCD
The only advantage of the K-5 over the K-3 is ISO 80, which provides an extra 0.4 stop of dynamic range.
autofocus, basketball, body, camera, consumer, cost, dslr, fa, fa*, ff, hope, ii, iso, k-3, lens, lenses, light, performance, photography, purchase, schools, sec, sensors, sports
Fotodiox Pro Adapter Hasselblad V to Pentax 645 (Pro HB-PT645) -A short review- veraikon Pentax Medium Format 4 06-25-2015 12:36 PM
Should I get Lightroom 4 or Corel Aftershot Pro to work with Paintshop Pro X4? klh Digital Processing, Software, and Printing 15 07-14-2012 10:37 PM
Wanted - Acquired: Tokina AT-X Pro (or Pro II) 28-70mm f2.6-2.8 Pepe Guitarra Sold Items 2 05-12-2011 01:16 PM
Client Etiquette, Question for the semi-Pro/Pro Photographers metalfab Photographic Technique 29 07-06-2008 07:04 PM
All times are GMT -7. The time now is 02:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
