I would say get the k-3 II, but wait until the FF comes out to make your decision. My main reason for this advice is, as bertwert said, the 70-200 on FF would have the same reach as the 50-135 on aps-c... which is enough for HS Sports, but if you're getting the 70-200 I would think you'd want to keep that zoom range. So i'd suggest K-3 ii and 70-200 - the k-3 ii is a great camera, better than some full frames. It doesn't seem that the type of photography you do really requires a Full Frame, which will cost more and be heavier, larger, and if you ever need better image quality from your k-3 ii... pixel shift!! although not for sports
I guess the main advantage of the FF for you would be better AF, which I think is almost assured... and better low light performance. But considering I can shoot ISO 1600 on a k-30 with really good results, i'm sure the k-3 ii can handle low light just fine... I don't think the cost is worth the upgrade to the FF.
---------- Post added 12-14-15 at 06:09 PM ----------
Originally posted by mattieyp3 Currently I shoot basketball at f2.8, ISO 8000, 1/800
Wow, your lighting must be really poor!! My basketball shots are done at f/4, ISO 1600, 1/500th. Isn't 1/500th fast enough?
