12-16-2015, 10:48 AM   #1
Dewman's Avatar
K-x problems
I have a K-x camera that will power up but the flash and the LCD screen will not work. Can anyone give me an idea what has caused this? I'm totally new to this camera model, so I'm very unfamiliar with it and it's workings.
Thanks in advance.
12-16-2015, 10:53 AM   #2
Did you purchase this used?
Is the flash popped up & on?
Is the LCD into display turned off during shooting? Try pressing the menu button.
12-16-2015, 11:04 AM   #3
bertwert's Avatar
Are the batteries fully charged?
12-16-2015, 12:52 PM   #4
Check the batteries first. Sounds a bit odd though. The Lcd may be off by default (pressing info a couple of times will fix that). If the batteries don't fix the problem, it sounds like it might have a problem
12-16-2015, 01:56 PM   #5
Canada_Rockies's Avatar
Don't forget that with Pentax, if the flash is closed, it won't pop up on its own. I prefer this behaviour, but my friends D7000 will pop the flash up on its own.
12-16-2015, 02:03 PM   #6
QuoteOriginally posted by Dewman Quote
I have two K-x cameras, which have had heavy use for three years, and occasional use since then.
Although I've never bothered with the on-board flash, the LCD on one of them became really intermittent.
Now I leave its LCD turned on all the time (rather than killing it with the INFO button).
Some users have found that pressing the rear panel back into tight contact with the body can help to revive a reluctant LCD.
12-16-2015, 03:43 PM   #7
clackers's Avatar
Thanks in advance.
Refund, Dewman.
camera, dslr, k-x, photography
Problems with Pentax K-x GrizzlyThumper Troubleshooting and Beginner Help 9 08-24-2014 07:40 PM
K-x problems tstaires Pentax DSLR Discussion 23 08-09-2011 03:26 PM
New K-x Problems... Xarcell Pentax DSLR Discussion 33 08-15-2010 04:21 PM
Apple fixes RAW problems with K-7 & K-x boriscleto Digital Processing, Software, and Printing 6 04-26-2010 11:50 AM
k-x problems ? crossing Pentax DSLR Discussion 2 01-18-2010 01:19 AM
All times are GMT -7. The time now is 05:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
