Originally posted by Mahadragon if the sample images I've seen thus far are any indication...how much better will the full frame perform? That is what I will be looking for.
I would not base my decision on upgrading from APS-C to FF based on the sample images. When the K-1 comes out, I trust one of our awesome PF members will post side by side comparisons with a K-3 or K-3II, and that will give you a better appreciation of the differences. Also note that web or monitor resolution does not show the full resolution and dynamic range qualities compared to an enlarged print. Ultimately for prints shooting in AdobeRGB instead of sRGB color space will improve the color bit depth.
New features aside, the main improvement going to FF includes:
-Higher resolution and greater ability to crop without losing resolution or to enlarge prints
-Greater dynamic range
-Lower light performance
-Wider angle of view given equivalent focal lengths
-Less depth-of-field and better bokeh
In other words, sample images shot in daylight with low contrast conditions at mid-range focal lengths and great depth-of-field viewed on a monitor are not going to look appreciably better in FF vs. APS-C.
But if your needs for "performance" are things like lighter/smaller body, more depth-of-field, smaller RAW files for faster processing in PP, then APS-C has the advantage. And the smart money goes to time or travel to take photos. The 'spare change' should go in improving your lenses. Once you've hit the ceiling with those two, it is time to step up to FF or MF.
