10-14-2016, 04:29 AM - 6 Likes   #31
One possible fix !
I would like to share my experience, it seems I successfully managed to fix the aperture problem on my K-30. And I discovered later a Russian forum talking about the same electronic part...
Anyway, the aperture controller mechanism is composed of several parts, including some kind of brake. This braking system didn't trigger in my case, causing the aperture blades to close all the way down at the few firsts activations. At first, I had to warm it up with 3 to 4 activations, then 5 to 6 a few months later, then about ten and then... I got bored, and took my screwdrivers !
Next to this double coiled electromagnetic brake trigger, are the aperture gears.
The way it works is not that difficult to understand when you can watch it by activating depth of field preview.
Here are the main steps :
- The gears are by some actuator.
-- So, the aperture lever translates.
-- So, the slotted encoding wheel turns.
-- So, the camera can count the number of slots passing through an optical sensor.
- When the required translation is achieved, those gears need to be stopped.
- The camera sends a current pulse in the brake trigger coils.
- The pulse releases the metal part (drawn in blue) from the attraction of the magnet.
-- So, the brake lever gets down.
-- So, the gears get stopped.
-- So, aperture is controlled !
The problem in my case, was the metal part not willing to leave the magnet's attraction. The gears were still working, the brake lever too. The pulse of current was also sent. So, I came up with the idea to slightly increase the distance between the magnet and the metal part by applying a thin layer of tin with a soldering iron (actually, it was more of a big drop that I thinned to the desired thickness afterwards). Logically, any non-magnetic material should do the trick !
After two times (the first one was two thick), it made my aperture controller working again !
The best part in this fix, is that the coils can be accessed just by removing the plastic covers. No need to recalibrate anything !
I hope this post will help you !
10-14-2016, 06:07 AM   #32
UncleVanya's Avatar
Nice explanation.
10-15-2016, 10:58 PM - 1 Like   #33
pentax360's Avatar
That same magnetizing problem happens with old phone ringer bells, they get magnetized and then the little striker that hits the bell sticks to the magnetized bell and it's silent.
10-19-2016, 12:56 PM   #34
QuoteOriginally posted by Shephard Quote
Out of interest, do you have any desire to fix other people's broken K30's? My symptoms sound the same as yours. I bought a K3ii to replace it, but would be nice to rescue the K30 before sale.
10-19-2016, 01:00 PM   #35
Not a Number's Avatar
Why not just degauss the metal part?
10-19-2016, 01:31 PM   #36
mee
QuoteOriginally posted by Ian.morgan Quote
Please make sure to include you have opened it up and altered the camera to repair an issue when you sell it.
10-19-2016, 01:54 PM   #37
RobA_Oz's Avatar
The same thought occurred to me. Doing it in situ would make the whole process a lot simpler, but I'm not sure (not having a K30) if the keeper is that accessible. You also have to figure out the polarity, to apply a reverse field, but I guess that would be the same on each body, so once one person has determined it, the rest can follow.
10-19-2016, 02:08 PM   #38
Advance Camera does this on K30's and K50's for about $150. So, there is some thought that it might actually work. I've given up on consumer grade Pentax and now have a K5 iis that I really like along with my m42 only K30.
10-19-2016, 02:30 PM   #39
QuoteOriginally posted by kernos Quote
Where is Advance Camera, just in case mine ever gives out? Do they do the repair specified above by Shepard, disassembling? Or do they do the demagnetizing, mentioned by Not a Number?
So far, so good with my K30.
10-20-2016, 12:47 PM - 1 Like   #40
QuoteOriginally posted by yucatanPentax Quote
My understanding is that they work with the magnets. Advance camera is in Portland Oregon and they have a website. I spent a bit of time talking to a someone who understood repair and got general info on the fix and price. Website is Advance Camera Repair
10-24-2016, 08:46 PM   #41
QuoteOriginally posted by RobA_Oz Quote
Degaussing is accomplished using an alternating current electromagnet. At least that's how we used to degauss CRTs. I think tape heads are demagnetized the same way. You gradually decrease the current, or move the degaussing coil away from the component you are trying to degauss. People used to magnetize the CRTs in their televisions all the time when they put their speakers beside the TV. Maybe there are other ways to do it...
Anyways, my K-50 is starting to develop the problem. I'm an electronic technician, so you can be damn sure I'll be cracking open the camera soon. Thanks for the heads-up, Shephard!
10-24-2016, 09:05 PM   #42
RobA_Oz's Avatar
QuoteOriginally posted by DougieD Quote
You're correct, of course - don't know what I was thinking of. Anyway, that makes it simpler, still
aperture, aperture motor, aperture motor failure, camera, dslr, failure, k-30, k-50, k3, motor, pentax, photography, precision camera, repair
K-50 aperture actuator mechanism failure? nw_mushroom Troubleshooting and Beginner Help 6 12-02-2015 07:13 AM
Fixing DA 16-50mm f/2.8 lens motor failure - is there a sticky, or wiki page? dartagnon Pentax SLR Lens Discussion 17 12-13-2014 03:20 AM
K-3 StartUp Buzz / Noise - Aperture motor? dMwBennn Troubleshooting and Beginner Help 22 12-12-2014 01:27 PM
Failure rate of the SDM motor - 100% ? peterh337 Pentax SLR Lens Discussion 21 04-06-2014 05:16 AM
Lens motor failure DC Cebula Pentax SLR Lens Discussion 3 02-18-2014 05:59 AM
All times are GMT -7. The time now is 01:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
