Show Printable Version 10 Likes Search this Thread
01-05-2016, 02:51 AM   #1
K-3 or K-3 II
Hey folks,
I am a pentaxian since 2007. Actually I have a K-30 and love it.
Plan to upgrade to K-3 or K-3 II. But I'm not sure which one I should buy.
Pro K-3
- internal flash (but did not use it that often)
- cheaper
Pro K-3 II
- GPS (cool feature for traveling, Astrotracer)
- Pixelshift (great for landscape I think)
- newer (newer is always better )
I like to travel a lot and my DSLR is always with me. Next trips go to Scotland in May/June, NYC in April and maybe Ireland in summer.
What would you guys recommend?
I've read so many tests, comparisons and threads, but still I can't decide.
I like to take landscape photography or architecture.
Next thing will be astro photography, that's pro K-3 II
Is the K-3 II worth the extra cost ? What do you guys think. Any ideas?
Best regards from Germany,
Phil
01-05-2016, 03:23 AM - 1 Like   #2
Except for what you've listed above the two cameras are virtually identical. So, if you don't need the built-in flash of the K-3 and plan to make use of the GPS, then the K-3 II would be the way to go. Pixel shifting is a nice feature to play around with, too.
01-05-2016, 05:18 AM - 1 Like   #3
You want a K3-ii? You'll almost certainly need a flash at some stage, and IIRC you definitely need a tripod to make best use of the pixel shift. If you already have those things, you're good to go. If not, you have to figure them into the cost of the camera.
If you are doing a lot of hiking and landscape/scenery shooting, then yes, the combination of GPS and pixel shift together would definitely be worth having. Regarding the astrophotography, I've already advised someone else not to buy for what you MIGHT want to do but buy for what you ALREADY do; however, given that you're a habitual traveller & your camera is a constant companion, you can already justify getting the K3-ii for that reason alone.
01-05-2016, 07:51 AM - 1 Like   #4
jatrax's Avatar
k-3 = internal flash
k-3II = GPS
Everything else is mostly irrelevant though pixel shift might be of some use in studio situations. So pick whether you want flash or GPS. I have both k-3 (my wife's) and k-3II. Never used the flash, always use the GPS. YMMV.
01-05-2016, 08:07 AM - 1 Like   #5
From the description of your use (hardly use built in flash, would use GPS) I'm guessing you're trying to get people to justify the extra cost of the k3ii. It's hard for a 3rd party to judge if these features are worth the cost to you, but for what it's worth, you have my moral support to go for the k3ii (but not my financial support).
01-05-2016, 09:14 AM - 1 Like   #6
Ron_Man's Avatar
Isn't the autofocus and SR slightly better on the K-3ii as well?
01-05-2016, 09:47 AM - 1 Like   #7
veato's Avatar
I went K3-II as I have an external flash when required. That being said I've used neither the Astrotracer or Pixel-Shift functions since owning the camera! I do intend to though so it's a nice to have.
01-05-2016, 10:09 AM - 1 Like   #8
If you don't use the internal flash, I'd say go for the K-3 II for GPS . If I were to travel to such scenic places I would appreciate being able to look up where pictures were taken after I get home and a few years down the road when memory fails. Definitely bring at least a decent monopod if you plan to use the pixel shift (which would probably be awesome if you plan to photograph historical ruins).
You can always buy an external flash later if you find a need for it. Just an forewarning, the popular Yongnuo YN-560 manual flash (original, II , III, and IV) has a short foot and won't mount on the K-3 II due to the larger hump housing the GPS, but works perfectly fine on the K-3.
01-05-2016, 10:41 AM - 1 Like   #9
Theov39's Avatar
There is a great K-3 II for sale in the marketplace for $600. That has to be one of the best deals on here. I'd stop debating the issue and grab it
01-05-2016, 10:59 AM   #10
I have an external Flash at home. It's an old pentax flash. So if I need one, I have one. Tripod from Manfrotto is also already present Can I use battery with the k-3 II like eneloops? Is there any other change from K-3 to k-3 II i haven't mentioned yet?
01-05-2016, 11:02 AM   #11
bertwert's Avatar
QuoteOriginally posted by pentaphil Quote
Which one?
01-05-2016, 11:02 AM   #12
bertwert's Avatar
Nope.
01-05-2016, 11:43 AM   #13
Kath's Avatar
As others have said, except for the features you mentioned, they're the same camera. I chose the K3II for the astrotracer and I don't need an onboard flash. I love the camera. For my needs, it was a vast improvement over the K50, particularly for cropping purposes.
01-05-2016, 11:55 AM   #14
Oldbayrunner's Avatar
Not without the battery grip bg5
There are a few but it more than likely would start a debate between the k3 and k3 ll owners. So in a nutshell not any that would be really noticeable.
Here in the States a new K3 ll is only apprx. 80.00 difference between the two body only models so price afaic made my decision to go with the K3 ll a lot easier.
01-05-2016, 01:07 PM   #15
QuoteOriginally posted by bertwert Quote
Which one?
Pentax AF-360 FGZ
camera, dslr, guys, ii, k-3, k-3 ii, k-3 or k-3, landscape, photography, thanks, travel
Japanese blogger tests K-3 II AF.C performance against K-3: Measurable improvement bwDraco Pentax K-3 & K-3 II 17 05-01-2016 10:04 AM
K-3 vs K-3 II Shake Reduction mee Pentax K-3 & K-3 II 11 12-02-2015 04:53 PM
K-3 or K-3 II zvon Pentax K-3 & K-3 II 23 09-04-2015 11:06 AM
Upgrade from K-5 to K-3 or Fuji XT1 or Oly EM1 zVratko Pentax DSLR Discussion 34 11-01-2014 11:56 AM
lots of different creative work- K-5, K-5 II/s, or K-3 yas_min Troubleshooting and Beginner Help 15 01-23-2014 08:05 AM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
