01-07-2016, 11:10 AM   #1
malfunction of shake reduction in K-5
Impossible to get shake reduction to work when taking photos (freehand) with my pentax k5 (used to work OK until recently). The symol for shake reduction displays with gray color, impossible to choose in the menu. (in video mode, it is possible to choose shake reduction.
Any suggestions??
Knufo
01-07-2016, 11:18 AM   #2
enoeske's Avatar
QuoteOriginally posted by knufo Quote
Any suggestions??
Knufo
Can you post an image with the exif intact? Some settings disable the SR, like using the 2 second timer. Maybe we can see which settings you are using and if something needs to be turned on or off.
01-07-2016, 11:35 AM   #3
jatrax's Avatar
Check your shooting mode settings. Likely you are in 2 second delay or remote control. Move it to regular shooting and re-test.
01-07-2016, 12:07 PM   #4
The Squirrel Mafia's Avatar
Try a factory reset if all else fails.
01-07-2016, 12:22 PM   #5
QuoteOriginally posted by enoeske Quote
I used "continues high"
bw Knut
PENTAX K-5  Photo
01-07-2016, 12:53 PM   #6
bertwert's Avatar
I don't think continuous shooting turns of SR, but I could be wrong...
01-07-2016, 01:06 PM - 1 Like   #7
enoeske's Avatar
bw Knut
I'm not seeing anything unusual in the settings that the forum shows. But here's the text from the manual regarding SR
The Shake Reduction function automatically turns off in the following situations. Note that the SR function cannot be selected when the following functions are set.
- B (bulb) mode
- Self-timer shooting
- Remote Control shooting
- Mirror Lock-up shooting
- when [Auto Align] is set to [] (off) in the [HDR Capture] setting
- when using the flash in wireless mode
So, just make sure one of these aren't set.
01-07-2016, 01:15 PM   #8
- B (bulb) mode
Thank you for all support.
I can now (at home) access the menu functioun (menu 4) to change the SR-function . In the field (very cold) this function was grey and not accessible. Very annoying, hopefully this will not happen again...
Normally the camera always change to SR when turning from self-timer to continous shooting.
Knut
01-13-2016, 02:53 AM   #9
tromboads's Avatar
I have had my SR fail on start up at times. That is, even with SR enabled, it just fails to switch on. I notice as I'm often using M, K lenses and it fails to prompt me for the focal length at times.
The solution?
Switch it off,
Give it a whack against my leg
Turn it back on.
01-13-2016, 08:36 AM   #10
QuoteOriginally posted by tromboads Quote
Thatís probably due to the lens not electrically shorting out the contacts in the lens mount for some reason, dirt or oxide perhaps. So the camera doesnít even know that a lens is mounted and thus doesnít ask for a focal length.
01-13-2016, 08:42 AM   #11
ZombieArmy's Avatar
The solution?
Switch it off,
Turn it back on.
Do you go "ayyyyyy" too?
01-13-2016, 10:08 AM   #12
Does it actually say "OFF" on the shake-reduction symbol? If it doesn't explicitly say OFF, then it should go green only when bumped or jostled, though that's pretty easy to get it to activate.
camera, dslr, k5, malfunction, photography, reduction, shake reduction
K-r shake reduction in RAW format timmijo Troubleshooting and Beginner Help 5 10-13-2014 03:47 AM
Shake reduction on K-5 going nuts melander Troubleshooting and Beginner Help 2 05-05-2014 11:57 AM
K-5 Shake Reduction Problem? krp Pentax K-5 2 07-06-2013 10:07 AM
K 5 Shake Reduction grhazelton Pentax K-5 5 06-07-2013 02:18 PM
K-30 shake reduction worse than k-r and k-5? soalle Pentax K-30 & K-50 14 01-04-2013 02:36 AM
All times are GMT -7. The time now is 08:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
