01-12-2016, 12:02 AM   #16
QuoteOriginally posted by Des Quote
Composition Adjustment Eye-Fi wireless transfer ISO up to 51200 Full time Manual mode during Video capturing mode Faster and more responsive M processing engine On-demand autofocus during video recording Supports 4 focusing screens Comes in 120 body colors and body design Kit lenses are WR versions
The K-50 has the same processor as the K-30, and the video features are the same. The K-30 also had composition adjustment, and its focusing screen is the same.
Everything else is correct.
01-12-2016, 06:02 AM   #17
Tom S.'s Avatar
Duplicate threads merged.
01-12-2016, 09:34 AM   #18
Theov39's Avatar
Composition adjustment is really neat.
What does this setting do?
01-12-2016, 10:10 AM - 1 Like   #19
bertwert's Avatar
QuoteOriginally posted by Theov39 Quote
01-12-2016, 11:56 AM   #20
UncleVanya's Avatar
Composition adjustment can be used as above or just to reduce perspective distortion induced by angling the camera up.
Here's a bit more info: How to Turn Any Lens into a Shift Lens - Tutorial Videos | PentaxForums.com
01-12-2016, 04:13 PM   #21
Des
Des's Avatar
Thanks for correcting this Adam. Shows why I shouldn't have relied on a third party review!
QuoteOriginally posted by RGlasel Quote
The rakish snout on the K-30's viewfinder can cause interference with fingers and focus rings., that's the biggest functional difference.
That's a good point, although personally I haven't had a problem with any of my lenses on the K-30, even those with a focus ring at the rear. I guess it depends on the lens and the fingers. It might also be more of an issue when the camera is held vertically.
Just one other small point about functionality. The "rakish snout" on the K-30 means a longer arm/cover for the pop-up flash. The pop-up flash probably rises a little higher than it does on the K-50 - which might provide slightly more clearance above large-diameter lenses. On the other hand, the Rogue Safari Flash Extender might not fit so easily on the K-30's pop-up flash. In an (excellent) thread about the Safari, Larry (@crewl1 ) reports,
"On the K-30 the flash cover is so long that you need to open the flash before attaching the Safari, and hook it over and then insert it to the hot shoe. If you try to open the flash with the Safari already on it bumps up against the bottom of the Safari."
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/256288...-extender.html
The Safari might be easier to fit on a K-50 because of the shorter arm on the pop-up flash, although I haven't seen any reports about this.
camera, dslr, k-30, k-50, k30, k30 vs, k50, pentax k30, pentax k50, photography
Hi: K30 vs K3 vs K50 etc. lu2 Welcomes and Introductions 6 11-16-2015 07:20 PM
Body Construction: K30 vs K50 Owltown Pentax K-30 & K-50 12 06-08-2015 07:03 PM
K5 iis vs K50/K30 SMeK Pentax DSLR Discussion 42 11-07-2014 12:39 PM
K50 + 18-135WR vs K30 + same. worth extra 170$ ? MK-x Pentax K-30 & K-50 15 08-31-2014 06:56 PM
K5 II vs K30 hjoseph7 Pentax K-30 & K-50 17 08-04-2014 06:38 AM
All times are GMT -7. The time now is 05:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
