I have a Asahi SMC Takumar 50mm 1:1.4 lens that I'm using with K-S2. I've taken a few shots with it, trying to see if my eyes are good enough for manual focus with the VF.
I turned on "Catch in focus" in the camera, set to manual focus. The way I understand how it works, while holding down the shutter release when the subject comes into focus the shutter releases and the picture taken. When I try to do this, as soon as I press down the shutter release the camera immediately fires, before the subject is in focus. This was with a stationary target and I was turning the focus adjustment ring, also the focus confirmation icon does not show when doing this. While just turning the focus ring without pressing on the shutter button the focus confirmation icon in the VF does light up.
What am I doing wrong?
---------- Post added 01-30-16 at 01:55 PM ----------
OK, I should have done a search first. I found this statement:
Originally posted by kmurphy220 Catch in focus is nice. Switch the camera to AF, hold down the shutter button and focus close to the area and then fine focus. It will fire for you. Burst shooting helps too. It works for all the K mount lenses, although not very good for M42 lenses since they don't have a metal connection right on top of the connections in the mount.
I did not have the camera in AF mode. I will try it again.
