Originally posted by Cee Cee not quite done,
correct me if I'm wrong, didn't you say the manual refered to how a non A lens would behave, ie. firing the flash at full intensiy . therefore it implies that a "A" lens would behave differently, but it doesn't say how the A lens would behave - like I said operation explained/suggested by omission, what am I supposed to have a crystal ball.
It doesn't explicitly say how an A lens will behave on that page, but it certainly should tell you that A and non A lenses behave differently with the built-in flash, which you said it didn't. That they are different is in a few other places as well, chart on page 239, the chart on page 255, the text on page 257, etc.
The chart on page 239 lists the flash functions with the Built-in flash. "P-TTL auto flash" is listed, but a manual flash mode is not. Nor is a multi-strobing effect. Nor is producing a coffee, I'm not going to be mad if it ignores my requests for a double double.
This "Full Power" with non-A lenses is an exception to the "P-TTL auto flash" behavior, and it was your assumption that it would carry over to M mode with any lens. An assumption based on what you want the camera's M mode to mean for the built-in P-TTL auto flash, not based on anything in the manual I can see. It's unfortunate you carried this assumption into a photo shoot and ran into problems, and I do understand your frustration from this, but that doesn't make it any less of a user error.
I'm done with the griping about the manual train of thought. If you have any interest in figuring out how to reliably trigger your off-camera strobes, I'm still happy to provide whatever help I can.
