07-03-2008, 10:34 PM   #16
Big I
Well, the first image you exposed for 1.6 seconds. The SR reduction is not going to help you in exposures of this length. I do not know of any stabilization feature, by any manufacturer, which will help you in exposures of this length.
It looks like the second image was exposed for 1/15th. The SR can be hit and miss at this exposure if you are not experienced holding for a long exposure. Do you have other shots at and around the 1/15th exposure time?
Regards,
Ernest
07-03-2008, 11:47 PM   #17
Big I,
You're expecting from shake reduction too much. You should expect that SR will help you to hand hold additional 2 f-stops.
Your test shots were made at 50mm focal length which means that for sharp handheld shot you should use 1/90 sec. exposure. Add another 2 f-stops for SR and you get 1/20sec. with SR.
So, please repeat the same test with shutter speed 1/20sec. Then you are going to see a difference.
07-04-2008, 01:19 AM   #18
QuoteOriginally posted by Edvinas Quote
Big I,
And besides that, do letthe SR system get to work. The SR needs some time to stabilize the sensor. (Wait for the little hand symbol after you half press ).
lock
07-04-2008, 05:48 AM   #19
Mike Cash's Avatar
Expecting SR to stabilize a 1.6 second exposure is just asking waaaay too much. That's what's wrong.
It is Shake Reduction.....not Magical Shake Elimination.
07-04-2008, 06:23 AM   #20
vizjerei's Avatar
Even both has motion blur in the photo, you can see that the one with SR on has more solid line than the one without.
1.6 sec is too long, in this kinda situation, you should choose a higher ISO, and looks like you should be using around ISO 400 in this case.
07-04-2008, 08:24 AM   #21
I was thinking the same thing. Maybe you are able to hold the camera steady. I have a friend that can get tack sharp shots hand-held with no shake reduction at 1 second. He is 92 and I suspect he has figured out a way to bring on a temporary form of rigamortise to do it. But, he does it.
Robert
07-04-2008, 08:53 AM   #22
Is he former military or a hunter by any chance? You learn certain tricks for firing with a scope to steady your body and hands.
07-04-2008, 10:40 AM   #23
Otis Memorial Pentaxian
QuoteOriginally posted by Big I Quote
Replies to all of you:
Here are some pictures with and without shake reduction. 50mm, ISO 100, F/8, 1.6 secs, handheld without any brace...
...What's wrong?
Hi,
Yes, both images show camera motion. For an exposure time of 1.6 seconds hand held, that is probably what you can expect. Sorry... There are limits to this kind of technology.
The rule of thumb is that you can expect 1.5 to 2 stops extension of exposure time. So if you shoot at 1/15 sec, the best you can expect is to get results similar to what you would get at 1/60 sec without SR. Now most of us can get reasonable results at 1/60 sec; so I would consider that 1/15 sec may be the practical lower limit of workable shutter speeds with SR. Sometimes we can do better, but very seldom.
07-04-2008, 12:31 PM   #24
arbutusq's Avatar
I find i can get reliable blur free photos until about 1/10 second and about 50% keepers around 1/6. Beyond that its beyond SR in my opinion.
07-04-2008, 02:23 PM   #25
According to the Exif data both shots had SR ON.
SR does nothing at the slow shutter speed you chose. It is designed to give you around two stops advantage, but at very slow shutter speeds any advantage is canceled by the excessive camera shake.
Try shutter speeds faster than one second (say 1/5) and see the difference.
Rusty
07-04-2008, 02:30 PM   #26
cardinal43's Avatar
QuoteOriginally posted by Jewelltrail Quote
According to the EXIF data I see, you are actually using a K20d after all. Can you confirm this for us? Thanks.
Regards,
Ernest
I checked the EXIF data on both photos, and they both show K10D
07-04-2008, 03:32 PM   #27
The EXIF shows 1.6 sec. No shake reduction will be able to correct shake at 1.6 sec. With your lens and camera, you could go to 1/8 or 1/4 sec, but you won't get a 1.6 sec exposure sharp. Unfortunately, miracles don't happen in 1.6 sec. You might consider buying a book or two concerning photography do's and don'ts.
07-04-2008, 03:53 PM   #28
QuoteOriginally posted by flyer Quote
...You might consider buying a book or two concerning photography do's and don'ts.
Ouch! I thought I told you kids to play nice!
Unrealistic expectations of technology does not equal ignorance of basic theory.
07-04-2008, 05:35 PM   #29
Big I,
Everyone is right here. You can't expect a 1+ second shot to be nice and sharp even with the best SR systems. And your camera has one of the best systems that I know of.
If you just plain don't have a tripod, or don't have it with you. You can always set your camera on a jacket, ontop of a table or stump or something to get your shot.
Use your imagination, and you'll get the shot.
This pic was taken on my other system, however to get the results I rested my camera on a fence, using my lens hood to prop the camera to the right angle. And took a 3.2 second exposure
I used a 10 second shutter delay ensuring I never moved the camera.
In this case I left my tripods in my car across town
07-04-2008, 11:04 PM   #30
Hello! This is my first post.
I have a problem with the Shake Reduction on my K10D: It doesn't seem to do any lick of difference! I have done hundreds of tests, and it has never made even the tiniest of differences. Does anybody know what's wrong? Can anyone help me?
I came from the forums at dpreview.com after getting frustrated because I never got replies to my questions. Hopefully this thread will at least have a few replies.
Thanks
At higher shutter speed, you won't see much difference. At too low a shutter speed, it can't do miracle.
So, the range it will work is at 2 to 3 stops lower than the "safe" shutter speed, which is 1/focal length (35 equivalent), but still, that varies person to person.
E.g., if you really want to test, you have a FA 35 lens attached to your K10D, say, the "safe" shutter speed is about 1/50th second. So, at 1/30th sec, the SR should work and make some difference and at 1/15th, it *should* still work. But at 1/8th, I am afraid you will get blur pictures again even you have the SR turned on.
camera, dslr, photography, reduction, shake, shake reduction
Tamron 2X TC doesn't work with DA 70mm SOldBear Pentax SLR Lens Discussion 0 10-27-2010 05:05 PM
how well does shake reduction work for video? and how does mJpeg stand up to grading clark Video Recording and Processing 23 06-22-2010 09:35 PM
Shake reduction julianactive Pentax SLR Lens Discussion 2 05-06-2009 04:13 PM
shake reduction oatman911 Pentax DSLR Discussion 17 03-07-2009 04:38 AM
Shake Reduction rfphill Pentax DSLR Discussion 3 07-12-2008 03:29 PM
All times are GMT -7. The time now is 06:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
