02-12-2016, 06:21 AM   #1
Senko's Avatar
Used k30 vs New k50
Found a pretty good deal on a used k30, like new, with low shutter activation's. I've recently been reading about the black screen of death on some of these k30/50 camera's.
How common is the k30 failure, from some of the forums I've read it seems pretty common.
Worth the risk to buy used 30k or am I better off buying a new K50 (twice as much $$$) but its brand new and I get the warranty.
Or skip all together and grad a k2s?
Thoughts?
02-12-2016, 06:58 AM   #2
16+k clicks on my K30 without any problem so far.
02-12-2016, 07:06 AM   #3
Senko's Avatar
Yeah, from what I'm seeing some people have no issues whatsoever while others have many - seems to be a coin toss. The K30 I'm looking at also has a slight creak in the handle, not to worried about that though, guessing its just a matter of tightening a few screws.
02-12-2016, 07:16 AM   #4
Kozlok's Avatar
I've had my K-30 for a long time, never anything like a black screen of death. I upgraded to a KS-2 last year, and for me, the upgrade was significant. If you can swing the extra cash, the KS-2 may be worth it. The two features I really like on the KS-2 are the -3EV focusing, and the flippy screen. The increased resolution is nice, sometimes, when I really need to crop. The resolution, to me, is significantly less important than the other features.
The only place where the KS-2 is worse is it won't wirelessly control an external flash with the popup flash. I did use that feature some on the K-30, so I'll probably just spring for some radio triggers soon, so there's a workaround for that.
02-12-2016, 07:17 AM   #5
THoog's Avatar
For every person that complains on PF about the aperture block failure (and complains, and complains, and complains ), there are at least ten who don't. My K-30 still works fine. I'm starting to think that they either fail fairly early, or never, so a used K-30 may actually be more reliable than a new K-50 (which has the same component that sometimes fails).
02-12-2016, 07:41 AM   #6
Emperor and Senpai
VoiceOfReason's Avatar
If you can afford the KS2 then I'd go for it.
02-12-2016, 07:54 AM   #7
Senko's Avatar
Tilt screen would be nice for macro, but not too worried about extra megapixels and or wifi. Any other advantage of the ks2 vs used k30? . It's almost triple the $$.
02-12-2016, 08:13 AM   #8
THoog's Avatar
This is my standard answer on K-30/50 versus K-S1/S2: The 20MP sensor gives you a little better detail in good light. In poor light, it has a little more noise than the 16MP, but the noise is of the luminance variety and fairly easy to clean up in post-processing, if you don't mind the extra step.
02-12-2016, 08:59 AM   #9
Emperor and Senpai
Higher resolution, no AA filter, better focusing
02-12-2016, 09:38 AM   #10
RGlasel's Avatar
QuoteOriginally posted by Senko Quote
If that feature isn't worth the extra money, the extra pixels, wifi and upgraded processor won't be worth it. As for K-30 vs K-50, it's even simpler. Is having a new camera compared to a slightly used camera worth the extra money? You can probably live with the pointier front of the prism and built-in flash housing of the K-30 for even a very small difference in cost, otherwise the two models are close to identical as you can get. I've had my K-30 since June 2012 and it has a few scuffs from rough handling but zero operational problems. If you are positive you will need to use the warranty of any new product, don't buy it!
02-12-2016, 10:15 AM   #11
I have never used a K30 or K50, but the problems that you are reading about have not been reported as being that large or wide spread. The oil splattering problems of Nikon's D800 D600 or the K5 were substantially much larger (and problems happen to every brand). The K30/50 is probably down in the single digit percentages. However, I will recognize that if it happens to you, it's an entirely different matter.
It all becomes a matter of statistics and probability. I know that it not a good answer - nor what you wanted to hear.....
02-12-2016, 10:30 AM   #12
QuoteOriginally posted by THoog Quote
My K30 failed after two years and my K50 after 7 months. So that's probably nothing to bank on.
02-12-2016, 11:32 AM   #13
Spodeworld's Avatar
I'd go for the K-S2 for the -3 EV focusing. I've noticed with the K30, it can struggle a little in low light.
02-14-2016, 08:17 PM   #14
my 2 year old K30 developed some serious aperature issues.
I also hear K50 people having the same issues.
So yeah.... looks like what ever they do...... K-5 or K-3 is the way to go....
02-14-2016, 11:36 PM   #15
Des
I've had two K-30 bodies and no problems (maybe 20,000 actuations between them). But I have no idea what the odds are. One poster in this thread was struck by lightning twice.
The things I notice most when I pick up the K-30 after using my K-3 are the slower and less precise AF, poorer low light focusing, the lighter build, and the noisy shutter. But it still takes very good pictures. The 16mp sensor is a gem. And the camera fits my hand very comfortably.
I'd look at a used K-5 too if it's within budget. You get the 16mp sensor with sturdier (flagship) build, quieter shutter, better low light AF and without the aperture control issue. Ideally the K-5iis because it doesn't have the AA filter, but the original K-5 seems to be quite a bit cheaper.
camera, dslr, k30, k30 vs, k50, photography
K30 vs K50 zoomlens Pentax DSLR Discussion 20 01-12-2016 04:13 PM
Hi: K30 vs K3 vs K50 etc. lu2 Welcomes and Introductions 6 11-16-2015 07:20 PM
Body Construction: K30 vs K50 Owltown Pentax K-30 & K-50 12 06-08-2015 07:03 PM
K5 iis vs K50/K30 SMeK Pentax DSLR Discussion 42 11-07-2014 12:39 PM
K50 + 18-135WR vs K30 + same. worth extra 170$ ? MK-x Pentax K-30 & K-50 15 08-31-2014 06:56 PM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, part of our network of photo forums!
