02-18-2016, 04:07 PM   #1
Spodeworld's Avatar
Wired remote and SR
Hi,
Does anyone know if when using a wired remote, does the camera auto-disable SR like it does when either the shutter delay or infrared remote modes are selected?
02-18-2016, 05:29 PM   #2
The camera behaves as if the shutter button is being pressed. The nicer wired remotes also support half-press. I use the Bower RCLC1R from Adorama which is essentially the same as many similar-appearing units with other labeling.
Bower LCD Timer and Remote Shutter Release (Model RCLC1R) reviews - Pentax Camera Accessory Review Database
The above review details the pluses and minuses.
02-18-2016, 05:49 PM   #3
Spodeworld's Avatar
So, the SR would stay on....thanks!
02-18-2016, 06:09 PM   #4
Under "Using the Shake Reduction Function" in my K-5IIS manual it states that "The Shake Reduction function will not fully work when shooting with a very slow shutter speed, for example when panning or shooting night scenes. In this case, it is recommended to turn off the shake reduction feature and use the camera with a tripod."
Under "Bulb Mode" in the manual, it does state that SR is not useable when in Bulb mode.
The manual I am referring to is the K5/K5IIS manual, pages 101 and 122.
02-18-2016, 06:21 PM   #5
Spodeworld's Avatar
Glad you brought this up. It was bulb mode that I was specifically thinking about
QuoteOriginally posted by C_Jones Quote
02-18-2016, 06:30 PM   #6
I thought that was most likely what you were referring to, since you had mentioned the cable switch (wired remote). I have a Vello cable switch. I use it with my K-5IIS and K-3II. Its formal name is "Vello RS-C1II Wired Remote Switch". It does not require a battery since it derives its power from the camera through the cable.
camera, dslr, photography, sr
Wired Remote Shutter Release C_Jones Pentax Camera and Field Accessories 46 02-23-2016 06:30 PM
K3 Wired Remote Problem? deaning Pentax K-3 24 04-04-2015 09:48 PM
Wired remote for 645D Don Boyd Pentax Medium Format 6 07-31-2014 08:23 PM
A very interesting Gizmo. Wired and wireless remote. Peter Zack Pentax Camera and Field Accessories 18 09-22-2010 12:02 PM
K7 and wired remote problem - anyone else? fillerupmac Pentax Camera and Field Accessories 7 08-01-2009 04:37 PM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
