02-26-2016, 11:37 AM   #31
QuoteOriginally posted by Ilovemypentax Quote
Pentax should have made this cam with a shutter speed dial. The program dial is the worst thing they ever invented other than Fuji's terrible 'focus by wire.'
Um... Maybe you have a use I haven't though of, but what about the front dial? I don't think I customized it much from default, and my K-3 front dial adjusts shutter speed in P, Tv, Av, Sv, TAv, and M mode (sometimes adjusting ISO or aperture to maintain exposure, depending on the mode). The only thing I can think a set shutter dial would gain is a visual indicator you can look at, but you can just look at the top display panel or in the viewfinder and see the same thing.
I won't be buying a K-1 for quite a while (if ever) but the customizable third dial is one of the features I am jealous of.
*Edit
Unless you mean you would prefer a shutter speed dial in place of the P, Tv, Av, Sv, TAv, M dial... In that case I think I understand what you mean. I can see the appeal of older cameras like the Super Program where you controlled all the settings, but if you wanted a specific setting to be automatic you set that knob to A / Auto. It was simple and easy to understand, but only if you know what all the knobs do. I'd say many novices tend to gravitate towards full Auto, so the extra knobs just confuse them.
My favorite advantage to this digital 'fly-by-wire' approach is that you can set up custom user modes that you can switch between with one knob and adjust many settings all at once. (If each setting still had a physical knob this wouldn't be possible.)
02-26-2016, 11:38 AM   #32
osv
QuoteOriginally posted by shiner Quote
This guy makes some pretty good points about FF vs APS-C. I think anyone selling their other bodies to go FF exclusively is making a huge mistake.
that link is loaded with false information, it's all been discussed multiple times here on pf already.
i would suggest reading this link, for a true understanding of crop vs. ff: Equivalence
02-26-2016, 01:01 PM   #33
pete-tarmigan's Avatar
QuoteOriginally posted by osv Quote
I couldn't get any farther than 1/3 of the way through the essay at the latter link (section titled "DOF / Diffraction / Total Amount of Light on the Sensor") because he doesn't define his acronym "CoC" and I couldn't guess what he means.
02-26-2016, 01:13 PM   #34
monochrome's Avatar
Circle of Confusion
02-26-2016, 01:38 PM   #35
Ron_Man's Avatar
=Pentax should have made this cam with a shutter speed dial. The program dial is the worst thing they ever invented other than Fuji's terrible 'focus by wire.'
Not too sure what you're saying here.. In Manual mode you can use the front dial for shutter and rear dial for aperture (or flip them around in the menu).
In SV (shutter priority mode), you can turn the front dial for shutter....
Not sure why the Fuji system is being brought up but the Pentax system is so easy a cave man could operate it in comparison.... (sorry to the Fuji fans but the menus and dials on those cameras are ridiculously and poorly implemented and not user friendly at all).
02-26-2016, 04:11 PM - 1 Like   #36
RobA_Oz's Avatar
Circle of Confusion is well-named, because, unless you've studied the optics involved, you wouldn't realise that it's one of the few indisputable facts in much of the discussion about equivalence, aside from focal length and aperture.
Really, osv's referenced article and the OP's are more or less lengthy discourses about the same thing, namely how the CoC influences our response to the final image. Why people feel a need to choose sides is beyond me, but the demise of the Megapixel wars seems to have left a gap for people to assert their righteousness and promote another one.
Not that I'm saying anyone here wants to do thatů
02-26-2016, 04:26 PM - 1 Like   #37
monochrome's Avatar
QuoteOriginally posted by RobA_Oz Quote
Just between you and me, I never took any of that scientific Art / Photography curriculum - I couldn't do the math then anyway - and IDK why light is measured in K either. I just want to make pretty pictures, sometimes with old cameras and lenses.
02-26-2016, 05:30 PM - 1 Like   #38
normhead's Avatar
A Circle of confusion is also incredibly easy to demonstrate. No need for advanced math. You know that simple lens you used to use to burn hole in newspapers when you're a kid by focusing the sun on it? When it's a tiny little point of light that burns the hole? That's the lens in focus. You know how as you lift the lens, there's a circle that get's bigger and bigger? That's the circle of confusion. Really, it's not rocket science.
02-26-2016, 06:08 PM   #39
RobA_Oz's Avatar
Well, let's not go into the Airy disc, just to create more confusion to the circle.
Kidding. You're right, of course, in that it is pretty straightforward, but so's rocket science, at its heart. It's just people that make it complex, and then it's a case of "my rocket's better than your rocket".
06-29-2017, 12:33 AM   #40
StefanMikes's Avatar
Sorry for re-living this old thread. Does anyone know for sure the two parameters of the K-1 sensor:
1. Pixel size (for diffraction limit calculation)
2. CoC?
I am more interested in the sensor pixel size. Any paper for actual diffraction limit for the K-1, provided a perfectly good optics of the lens?
07-02-2017, 12:51 AM - 1 Like   #41
QuoteOriginally posted by StefanMikes Quote
2. CoC?
Divide 36 mm by the number of pixels of the longest side and you have pixel pitch. CoC is what you accept as acceptible CoC for DOF calculation. Use multiples of pixel pitch co compare between cameras with different pixel pitch. If cameras has pixel pitch of 5 micron, acceptible CoC can be 10-15 micron or 3x the pitch. DOF Master website online explains details and does all the calculation for you.
Diffraction limit is easily estimated. For visible light the f-stop number should not be larger than the pixel pitch in micron. Use a factor of two and diffracion typically becomes visible over other optical imperfections. Pixel pitch 5.6 micron would tell you that diffraction becomes a factor from f/11.
07-02-2017, 01:27 AM   #42
Moderator PEG Judges
Kerrowdown's Avatar
K-1 As Your Only Body?
Just get a second K1... then you've got two bodies and it will not be only one.
Sorry but I couldn't resist adding that comment to this old resurrected thread, but I do wonder if any of the views mentioned here have now changed with more folk having K1s.
camera, dslr, ff, photography
For Sale - Sold: Pentax K-5IIs Body, Only 1 Months Old, Under 300 Clicks ddjchemist Sold Items 2 12-28-2014 08:00 PM
For Sale - Sold: Pentax K-01 black (body only), shutter count is only 45! transam879 Sold Items 2 11-09-2014 11:22 PM
Pentax K-5 II $769 body only including delivery (today only) at Kogan Australia Foma2 Pentax Price Watch 2 10-22-2013 07:34 PM
Hey photogs! You're only as good as your gear. Says Nikon... einstrigger Photographic Technique 76 10-11-2011 05:43 PM
K-m to be available as *Body Only* in UK manuletterbox2 Pentax News and Rumors 11 09-25-2008 03:03 PM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
