02-28-2016, 02:38 PM   #1
Issues (?) with my K3ii
Let me be brief:
1) I was just at a family party and I gave my aunt my camera to take pictures. She likes taking pictures but doesn't know anything about settings so I just put it in Tv mode and fix shutter at 1/180 so she doesn't get any blurry pictures. I have the flash on (Metz 50 AF-1) at PTTL at -2.0 EV just to fill shadows. I further have the in-camera at +0.7 EV because I like bright pictures. The idea was that the camera controlled the aperture and ISO correspondingly. All the shots were done at ISO 100 and very underexposed. Why? I have the ISO at 100-3200. What settings could affect this?
2) When I half-press the shutter button it focuses as it should, but sometimes it doesnt? Some times (not always) no matter how many times I half-press it won't focus and I have to press the AF button and then it focuses. Why is this?
Thanks.
02-28-2016, 03:08 PM   #2
LeDave's Avatar
1) Post some examples of the photos, attached exif would help. and 2) Tell us what lens you are using.
02-28-2016, 03:14 PM   #3
QuoteOriginally posted by LeDave Quote
1) I will post some pictures when I get home.
2) DA* 16-50mm f/2.8
02-28-2016, 03:18 PM   #4
LeDave's Avatar
QuoteOriginally posted by Moropo Quote
Sounds like your 16-50 is starting to fail with it's SDM. You can always get the lens to convert to screwdrive if you find it being intolerable. Here is a thread that may help as well.
02-28-2016, 03:24 PM   #5
Otis Memorial Pentaxian
Auto ISO?
02-28-2016, 03:38 PM - 1 Like   #6
Into The Lens's Avatar
Did your aunt take the lens cap off?
03-15-2016, 03:15 PM   #7
Sorry for delay in response.
The ISO was not in auto, it was fixed at 100, hence the outcome described above. In order to put it in auto I had to press ISO button and then the green button? I found this out by searching the forum. Why is there no menu-setting controlling this?
In regards to focus I will be looking into converting it to screw-drive I guess. The person I got this lens from said the SDM motor already failed and he had it fixed/replaced through warranty. Is it common for the SDM to fail after fix?
03-15-2016, 04:13 PM   #8
Auto-ISO is controlled via the info button menu on the K-3II, but there is also the aforementioned shortcut combination.
03-15-2016, 05:21 PM   #9
aleonx3's Avatar
Before I finished reading all the posts... I had thoughts that you are not using auto-ISO... hence you get the underexposure result... but I would go for full manual mode when using flash. Regarding the second problem you experienced, I can only say that it is possible that SDM motor fails.... I have both DA*16-50 and DA*50-135 lenses, I have no problem since the SDM motors were replaced. And I don't them as often, when not being used, I store them standing up (front element down) in the pouch. I never have any problems since then.
button, camera, dslr, ev, half-press, iso, photography, pictures, settings, shutter
Pentax K3 / K3II problems/issues Surovi Pentax K-3 55 07-06-2016 11:04 AM
Card issues with my K5IIs ronuser Troubleshooting and Beginner Help 6 03-24-2015 06:27 PM
MAJOR issues with my K5!! Senseriffic Pentax K-5 21 12-11-2012 09:10 AM
Dust issues with my K-r sharepointalex Pentax K-r 62 03-14-2012 08:52 AM
issues with my k1000 elevatormusic Troubleshooting and Beginner Help 8 12-02-2011 09:17 PM
All times are GMT -7. The time now is 10:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
