Originally posted by Fred Shermock Ok in LV, I can zoom in by clicking OK and dial up 6x....but second I try to push the trigger, LV quickly reverts back to distant view....this under AUTO or M....6x zoom subject won't "stay" in view finder....how do I 6x zoom in get zoomed subject to stay in LV, and snap the pik?
That Digital zoom thing only works in live view and is meant as a focusing aid. It is
not an effect for the final photo; it is only used so you can more clearly see where the lens focused in live view. It also opens the lens' aperture, so DoF is thinner. It is very useful if you use Manual focusing, especially older lenses with bright aperture (f-number lower than f2.8)
Zooming on DSLR cameras can only be done via the lens - some lenses have a zoom ring with a certain range (for example, 18-55mm means the lens' focal length can be changed from 18mm all the way to 55mm. If a lens has just one number instead of a range, then it has no zoom (DA 35mm f2.4, for example, has no zoom))
A smaller zoom range generally indicates a better image quality on a given price point.
