02-29-2016, 01:41 AM   #31
Closed Account
The K-1 looks to be an absolutely superb camera, but my photography skills are not up to its level by quite a long way. I currently have a K-3 which is not being used to its full potential - for now !! One day I hope to rise to such levels. In the meantime, I am going to be watching with great interest which APS-C equipment I can pick up soon. Good luck to all that get the K-1.
02-29-2016, 03:13 AM - 1 Like   #32
I moved into photography with DSLRs because I had reached a point with my cell phone camera where I could no longer take the photos I wanted, so I did my research and got the k-50. Wih only the 18-55 kit lens, I am still learning the ropes and looking to expand my lens selection before I even think of upgrading. When (and if) I upgrade to another Pentax body it will be due to either needing a new one because the one I have no longer works, or no longer meets my needs. Since I have no need or desire to go pro, I do not know if I will ever need a full frame.
02-29-2016, 03:40 AM   #33
ffking's Avatar
I've been scanning a load of recently recovered 35mm slides and realising just how different FF is to APSC. I love the look of my 35mm telephoto shots despite the reduction in effective magnification, and the smoother gradations will definitely be a plus. Apsc is great for macro - more magnification and pixel density for fine detail, so I won't lose the K3 until a better model comes along (and my finances have stabilised) but I can't imaging not finding my way to a K-1, even though I currently don't have the money - a great incentive to get out there taking saleable pics
02-29-2016, 03:50 AM - 1 Like   #34
QuoteOriginally posted by pjv Quote
That's precisely the other way around! The smaller the sensor, the more skills you need to get high quality results. Smaller sensor / higher pixel density and lower high iso performance, is much harder to get good photos in lower lighting conditions. Remember the rule of thumb for the shutter speed = 1/focal_length for 35mm format... for APSC with same pixel size you need 1/(1.5xfocal_length). The full frame system expands a lot of the conditions in which you get high quality images without taking care. For example, when lighting is not at its best, you need to help the APSC sensor with controlled lighting with additional speed-light for instance, where it would not be necessary with a ff sensor.
So if you think you are short of skills for a K-3, that may not be the case anymore with a K-1.
02-29-2016, 03:55 AM - 2 Likes   #35
Otis Memorial Pentaxian
clackers's Avatar
No, it's easier to take pictures with a bigger depth of field.
That's what throws people going to a DSLR after using their phone for photography.
02-29-2016, 04:01 AM   #36
zzeitg's Avatar
I will buy K-1. Well most probably. And if not K-1, then K-1 II.
However, I will surely keep my K-7 and K-3 and use both APS-C and FF alongside. I don't see FF as APS-C replacement, but as a complement.
Exactly. I'm truly impatient to mount my A50 f1.2 or Revuenon 55 f1.2 or Sigma 85 f1.4 or Samyang 135mm f2 on K-1 to see the razor-blade only deep (well... shallow) DoF.
Most of the lenses is soft at widest aperture, so my expectation is that I would go to higher f number without rapid increasing of DoF (because FF) while getting sharper shots. FF lenses on FF sensor. Finally.
02-29-2016, 04:02 AM   #37
No, it's easier to take pictures with a bigger depth of field. That's what throws people going to a DSLR after using their phone for photography.
Yes you're right, but depth of field is only one thing among others. When I moved from compact camera to DSLR, I knew nothing about DSLR, DoF etc, and from day #1, my pictures were all better, for me it was a "Woww! this DSLR rocks" and since I had a K200D, I never used a compact camera again.
02-29-2016, 04:13 AM   #38
Closed Account
You buy me a K-1 biz-engineer and I will test your theory on skill levels.
02-29-2016, 04:21 AM   #39
StephenHampshire's Avatar
Provided the high ISO performance is up to scratch, I will buy a K1- my target is towards the end of the year - we have Black Friday deals here in the UK now so this might be a good time to get one. I have a lot of FF glass and envisage using mostly fast primes with the K1, although I have a Tamron 28-75 f2.8 to use as a walkaround. I will keep my K3 (can share batteries!!) and APS-C lenses
02-29-2016, 04:22 AM   #40
Ah yes, it's about money, not skills then. My theory is easy: simply imagine the world most skilled photographers, they should be content with Point&Shots camera, but they don't do that, they use cameras up to the largest possible format, so if larger formats require more skills to get the same results, then the reason why they still buy more expensive cameras must be that they need to burn the overflow of money that they earn. I bet if you take a 645z set in green mode, you'll get better results than a k-3 in green mode.
02-29-2016, 04:27 AM - 1 Like   #41
Closed Account
Not at all. I can easily afford one of these beauties, but I think I know my capabilities a bit better than you.
02-29-2016, 04:37 AM   #42
I understand.
02-29-2016, 04:49 AM - 1 Like   #43
ffking's Avatar
Right - so YOU get ME a K-1 (I could take advantage of the upgrade but can't afford it) and you can have it back when you're good enough! Sounds fair to me
02-29-2016, 04:51 AM   #44
clackers's Avatar
QuoteOriginally posted by ffking Quote
So many scammers on this thread! ☺
02-29-2016, 05:23 AM   #45
Gah, I just don't know. I never intended to get a FF, as long as I assumed the price would be upwards of 3000€! For the expected price after maybe waiting till the end of the year, I am not so sure anymore.
Of course I don't *need* the camera, but in recent months I took a few shoots with my good old K-5 where I wondered if a higher resolution and less noise would have made a difference.
The problem is, these were wildlife photos done with the DA*300 or macros with the DFA 100. So if I switch to the K-1 I gain ISO not resolution in practice, unless I invest in expensive and heavier glass. Switching to the K-3 I would gain resolution but would not reduce noise...
And then there is a certain nostalgia, I'm old enough to have started with 35mm film, so the FF would be closer to the way I used to work then. Also I suspect I'm being a bit irrational here
aperture, apsc, apsc shooters, camera, dof, dslr, equivalence, f/2.8, f/4, film, format, formats, frame, glass, image, iso, k-1, k-3, k1, k3 2, lenses, light, pentax, people, photography, photos, platform
645D How To tell how many Actuations rollsman4 Pentax Medium Format 2 03-10-2015 05:51 PM
Macro How many of you macro shooters photolady95 Photographic Technique 40 09-06-2014 10:12 AM
How many will admit to using the "GREEN" Mode Driline Pentax K-5 & K-5 II 60 03-27-2013 01:03 AM
How many DSLR makers will there be in 5 years? Impartial Photographic Technique 16 10-15-2010 02:16 PM
how many shutter cycles are to many on a used slr mikejax19 Troubleshooting and Beginner Help 14 08-30-2010 09:34 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
