07-06-2008, 10:05 AM   #1
K10D dynamic range
Let me give you the scoop.
I had a Canon 300D and just shot the kit for a long time. Then I got a 50mm, then the Sigma 10-20, then the 35mm f2, sold the 50mm. Then I got sick of the lag of the 300D on start up and got a black (hated the silver 300D's looks) 400D. One week after I shelled out for the 400D Pentax released the K10D. Purchased a 100mm macro.
Now that there is a K20D, people are willing to part with the K10D for about 500 dollars it seems.
Now I only really shoot RAW, I use lightroom. I looked over the review of the K10D again at dpreview and many lens tests. The item that concerns me is the dynamic range test. I find I don't have enough dynamic range with my 400D and according to their result there is strange clipping of highlights and no real roll off for the K10D while the K20D has a normal roll off.
Is this true, that the DR is much better on the K20D? I guess landscape people would notice most dark shadows and brights skies.
I'm attracted to pentax for the limited lenses and the in body IS. I don't like how heavy the bodies have gotten though.
I'm mostly just interested in the DR issue I am asking about. I also love that Pentax shooters are a community.
07-06-2008, 02:33 PM   #2
Wheatfield's Avatar
QuoteOriginally posted by drwho9437 Quote
First, the best dynamic range on the K10 is had at ISO 100, and is ~11 stops. The DR progressively shortens as you raise the ISO, until at ISO 1600 you are down to ~9 stops.
This is still a couple of stops more DR than the longest range colour print films ever were.
While I haven't actually tested the K20, my impression is that the DR is similar to that of the K10, perhaps a little longer. The K20 does have a dynamic range extension in the Fn menu (in ISO adjust) that seems to increase the DR by about a stop, at the cost of losing 100 ISO.
07-06-2008, 03:13 PM   #3
Jodokast96's Avatar
According to Dpreview, the K10D has a DR of 7.3 stops (-4.5 to 2.8), the XTi 8.4 stops (-4.9 to 3.5), the XSi 8.7 stops (-5.1 to 3.6) and the K20D 9 stops (-5.8 to 3.2). Not sure where you got 11 stops from, or which is right for that matter, but that's a pretty big difference. At any rate, it seems pretty clear that Pentax has opted to favor shadow detail as opposed to highlight detail.
07-06-2008, 03:21 PM   #4
QuoteOriginally posted by Jodokast96 Quote
According to Dpreview the K10D has a DR of 7.3 stops (-4.5 to 2.8), the XTi has 8.4 stops (-4.9 to 3.5) and the K20D 9 stops (-5.8 T
Correct those numbers and charts are my reference above.
07-06-2008, 06:21 PM   #5
arbutusq's Avatar
Those charts are for Jpegs only. Imaging Resource has a chart that ranks the raw performance of all these cameras. If you check the K10d review on that site you'll find it.
07-06-2008, 06:29 PM   #6
QuoteOriginally posted by arbutusq Quote
I didn't think they were because they talk about headroom in ACR as well, but I will look at IR as well...
Edit: you are correct, the main part is about the JPEG engine which I don't care about really..
Also looked at the IR data, but it doesn't have as good a commentary. In the raw comparison the K10D fairs better, and probably it would be OK. Thanks for pointing it out to me.
07-06-2008, 07:32 PM   #7
Wheatfield's Avatar
I got my data from a fellow on the Pentax Discuss Mail List who, among other things, has worked for Adobe and Nasa.
He wouldn't have been testing jpegs, which do have a rather short DR.
07-07-2008, 02:46 AM   #8
DPreview has a wrong method for measuring.
They measure DR in JPEGs. Numbers they measure cannot be called Dynamic Range.
And topic starter mentioned here that he shoots in raw.
07-07-2008, 02:53 AM   #9
Jodokast96's Avatar
Hey, easy guys. I never said Dpreveiw was right.
07-15-2008, 11:29 AM   #10
Histogram
Slightly off topic here, but I'm wondering how all this relates to the histogram the camera shows. IIRC it shows a 4 or 5 stop range in the histogram. But even the most conservative number cited here says the camera records a 7.5 stop range.
So what gives? Is the histogram showing me a smaller range than what the camera actually records? If so, which parts of the true range are getting clipped out of the histogram?
07-15-2008, 11:33 AM   #11
Gooshin's Avatar
the histogram you see represents the histogram of the jpeg output at the settings that you set it at.
usualy a histogram that clips highlights on your screen means you still got some headroom in ACR
07-15-2008, 11:44 AM   #12
QuoteOriginally posted by Gooshin Quote
Interesting. Seems like it would be handy to get the true range, or at least something closer to it. I'll have to look at the available settings when I get home to see if that's possible.
I don't suppose you would know off the top of your head?
07-15-2008, 11:46 AM   #13
Gooshin's Avatar
QuoteOriginally posted by breischl Quote
you "get used to it"
meaning, you get used to looking at your LCD screen and having a good idea of how its going to end up on your monitor.
07-15-2008, 01:37 PM   #14
Canada_Rockies's Avatar
The setting I use is the highlight blinkies. I expose to have one or two very small specular highlights that are blown out (blinking red). Then, I look for shadows that are beyond recovery (blinking yellow). I find that normally, I don't have the shadow blinkies. The blinkies are rated at the jpeg level, and with one or two tiny ones, they are not usually blown out on my RAW images when I open the image in DxO or Adobe.
I shoot only RAW - for the same reasons that I used to shoot Fujichrome Velvia - the better base quality.
07-15-2008, 02:35 PM   #15
Thanks guys. I had pretty much arrived at the same conclusions myself. I was just hoping there was a way to make the histogram accurate, instead of needing to work around it's inaccuracies.
The workarounds & guessing are usually fine, but occasionally I get it wrong and screw up a shot. It seems silly that we have to guess at this stuff when the camera already knows the answer.
I suppose it would be hard to show a 9-stop range on the LCD, but does anyone even look at the midtones on the in-camera histogram? I'd be happy if it showed me the bottom two stops and the top two stops, with nothing in between.
50mm, camera, dr, dslr, k10d, k20d, pentax, people, photography, range, roll
k20d or k10d - which has better dynamic range Michael Barker Pentax DSLR Discussion 10 12-18-2008 10:47 AM
Dynamic Range Rene` Pentax DSLR Discussion 6 09-25-2008 07:46 AM
Dynamic Range Vlad Photographic Technique 5 06-01-2008 10:40 PM
K10D dynamic range...ISO100, single exposure HDR d.bradley Pentax DSLR Discussion 15 02-10-2008 06:11 PM
Impressed by Dynamic Range of K10D Avantphoto Pentax DSLR Discussion 11 05-25-2007 06:37 AM
All times are GMT -7. The time now is 10:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
