03-15-2016, 07:44 AM   #16
csa
csa's Avatar
My wildlife shots are hand-holding my K3 with the Pentax 55-300 plus a 1.4X TC. I hold the lens at the bottom with my left hand, tuck my elbows in against my body. I stand with my feet wide apart. This works for me.
Camera
PENTAX K-3
Focal Length
300mm
Aperture
f/10
Exposure
1/400s
ISO
2500
03-15-2016, 11:14 AM - 2 Likes   #17
wtlwdwgn's Avatar
QuoteOriginally posted by jackloganbill Quote
I also purchased a monopod, but that is not working out. I feel like a drunken sailor with it!
I did too with the one I had. I also either tripped over it or whacked somebody with it.
03-15-2016, 11:21 AM   #18
Dewman's Avatar
QuoteOriginally posted by wtlwdwgn Quote
I bought one and mounted the Beike BK-03 ball head on it and I use it almost exclusively. I suppose, like a lot of gear, it takes a little getting used to, but my photographs are much sharper when I use it. But, it's just a person thing. Works for some, not for others. I have hand tremors, so it's almost a necessity for me.
03-17-2016, 01:00 PM - 1 Like   #19
slip's Avatar
Beer my friend! I have tremors as well and am having a hard time getting quality shots without jacking the ISO and shutter speed. looking forward to more suggestions
Randy
03-17-2016, 07:59 PM - 2 Likes   #20
Dewman's Avatar
QuoteOriginally posted by slip Quote
Randy
I bought my monopod (Targus) at Walmart. Go on and laugh if you want, but don't do so until you try one. $15.00. Works beautifully, and with the $20.00 Beike BK03 ball head on it, it's a very viable combination that works to perfection for ME! I've found that it works wonders as a sort of cane. When I need to get down on one knee for an especially low shot, I have a hard time getting back up and the monopod is indispensible for that purpose!
I know that there are those who will read this and laugh at the "on the cheap" way I went about it, but It fit my budget and it WORKS FOR ME! I can't afford the high dollar Manfrotto and other big brand name pieces of equipment, so I do the best with what I can afford. I'm still havin' fun and turnin' out some fair photographs.... and that's what I set out to do..... so I guess I'm successful in my efforts.
03-18-2016, 06:33 AM   #21
slip's Avatar
QuoteOriginally posted by Dewman Quote
Nothing wrong with that!
I already own a monopod but don't use it as I never did get used to it 😊
The chest pods look interesting, though
Randy
03-19-2016, 11:21 AM   #22
My long time solution
Long ago I discovered the Leitz Mini-pod with the large Ball Head. I will never be without one. It has a taller head than any other mini pod and works better than any other I have seen. Mount the camera on the head, rest the open pod on your chest and adjust the angle on the ball head so the camera is eye level. I can hold the camera sufficiently still to make 1 sec exposure. You can also press the tripod against a handy wall, post, tree etc. It also functions like any other mini pod. If you are using a long lens with a tripod mount on the lens, it works the same way. Only negative is they are somewhat expensive, running well over $100 used (though the last on I bought was only $75).
Be sure to turn off your SR when on a tripod. The camera can confuse subject movement with camera shake and actually blur your subject.
03-19-2016, 03:18 PM   #23
Des
Des's Avatar
Or like those circus performers using poles with plates spinning on top.
There's plenty of general advice about how to use a monopod. This one is clear and succinct: https://www.nikonians.org/monopods/what_monopod_3.html
To use the monopod at other than 90° to the camera/lens, you will need to use some kind of a head on it.
Dewman, no-one is scoffing - we are always interested in cheap practical solutions.
QuoteOriginally posted by jeverettfine Quote
Like this? Article: Table Top Tripod as "Chest Pod" Thanks for the tip.
03-20-2016, 06:29 PM   #24
Wheatfield's Avatar
I have the Pentax K-50 and just purchased a Tamron 18-200MM lens.So far it seems superior in clarity to my kit lenses but I am having trouble holding the camera still / steady with the somewhat larger and heavier lens; the camera is moving all over the place. So, what is the technique for holding the camera steady?
Thanks
Jack
Hold the camera body with the right hand, cradle the lens with the left hand. Tuck your elbows in against your body, breath in, breath out, breath in, breath out slowly and release the shutter while exhaling.
Try it, you'll see.
03-20-2016, 07:27 PM   #25
sandbasser's Avatar
I too use the Targus from Walmart. Haven't tried it with a ball head, but now I think I will. And, an added benefit it makes a great walking stick. I can put a surprising amount weight on it. Helps greatly up steps without handrails, etc.
03-22-2016, 06:00 AM   #26
jacamar's Avatar
Do any of you disable SR when you use a monopod or brace the camera against something? I was thinking about that this weekend after I was able to rest my camera on top of a handy fencepost when I took the crane pics in the 300mm+ thread. They weren't as sharp as I really wanted despite 1/1000 sec at f/10, and I was wondering whether I should have turned off the SR. I was still holding the camera and there was room for a bit of movement, but the support was pretty solid.
03-22-2016, 09:17 AM   #27
Dewman's Avatar
QuoteOriginally posted by jacamar Quote
Personally, I never disable SR unless I use the 2 or 12 second delay, then the camera does it for me.
03-24-2016, 07:34 AM   #28
pacerr's Avatar
A tripod has one too many legs an' a mono pod has one too few. My solution? A bi-pod.
Find a cheap tripod and remove one leg. Use a quick disconnect head if you want to frequently separate the camera and support. I use a magnetic disconnect which is quick but secure enough for the purpose. When max mobility is needed, I simply use a V-bracket as a rest for the lens.
Two legs is MUCH more stable than one, much less inconvenient, and using the camera neck strap as a tether allows hands-free for doin' other stuff like changing lenses. And a bi-pod often trumps the 'no-tripods-allowed' rule if a mono-pod's allowed.
The largest Gorilla-pod also works fine with two legs resting on your chest and the third hooked over a shoulder. Better than any gun-stock type support I've ever tried.
03-24-2016, 11:14 AM   #29
deus ursus's Avatar
QuoteOriginally posted by pacerr Quote
Why not just extend two legs instead of three? No need to butcher a perfectly working tripod when you can have a three-in-one solution: Extend one leg and have a monopod, extend two legs and have a bipod, extend all three legs and have a tripod. :-)
03-24-2016, 11:28 AM   #30
ffking's Avatar
If you do use the otherwise excellent PF article, make sure you don't make the mistake of keeping your lens cap on - this can seriously slow shutter speeds and lead to very disappointing results
button, camera, dslr, focus, photography, release, shutter, vs
Pentax SMC coatings still hold up after more than 40 years! bwDraco Pentax SLR Lens Discussion 20 07-05-2015 03:56 AM
K-3 ii & Pixel Shift: How still is still? ahw Pentax K-3 19 06-08-2015 09:31 AM
How long will you hold on to your K7? Tony3d Pentax DSLR Discussion 114 11-12-2010 06:26 PM
How to hold a DSLR so it doesn't weigh you down tilling Troubleshooting and Beginner Help 20 06-17-2009 12:12 AM
What is your technique to hand hold the camera still Eastern Shore Charlie Pentax DSLR Discussion 29 11-28-2008 04:59 PM
All times are GMT -7. The time now is 09:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
