03-24-2016, 09:50 PM   #31
pacerr's Avatar
QuoteOriginally posted by deus ursus Quote
Why not just extend two legs instead of three?
There can be a disproportionate reduction in bulk and weight depending on the tripod used and how much you remove from the frame.
Also you may have to disconnect the brace for the third leg for many economy tripods or all legs want to extend together -- otherwise it makes use as a tripod very unstable and inconvenient and it becomes impossible to use as a bi-pod.
However, I DO have one tripod with the third leg's support arm replaced with a flexible chain that allows for your suggestion.
03-25-2016, 02:01 AM   #32
deus ursus's Avatar
I can see that with that design it can be a challenge. My tripod doesn't have the support arms, so I think it can be done. My previous post was just an idea I got from reading your post, so I'll have to try it to see if it will work or not.
button, camera, dslr, focus, photography, release, shutter, vs
Pentax SMC coatings still hold up after more than 40 years! bwDraco Pentax SLR Lens Discussion 20 07-05-2015 03:56 AM
K-3 ii & Pixel Shift: How still is still? ahw Pentax K-3 19 06-08-2015 09:31 AM
How long will you hold on to your K7? Tony3d Pentax DSLR Discussion 114 11-12-2010 06:26 PM
How to hold a DSLR so it doesn't weigh you down tilling Troubleshooting and Beginner Help 20 06-17-2009 12:12 AM
What is your technique to hand hold the camera still Eastern Shore Charlie Pentax DSLR Discussion 29 11-28-2008 04:59 PM
All times are GMT -7. The time now is 06:59 PM. | See also: NikonForums.com, part of our network of photo forums!
