03-11-2016, 10:22 AM   #1
bertwert's Avatar
Abnormal exposure...
I've noticed recently (and have evidence from beginning of January) that the first photo I take when I turn the camera on will be dark. Two images taken right after each other with the same exposure the first will be dark and the second won't. See attached images. The lighting conditions did not change.
What could be causing this?
PENTAX K-50  Photo
PENTAX K-50  Photo
03-11-2016, 10:27 AM   #2
If it happens with more than one lens, I would suspect the infamous K-30/K-50 aperture controller issue. If you camera is still under warranty, it might be time to give Ricoh Canada a call to arrange service.
03-11-2016, 10:42 AM   #3
bertwert's Avatar
I refuse to believe this!
NO NO NO.
BUt the thing is it is only happening when I first turn on the camera, every time after it is fine...
03-11-2016, 11:02 AM   #4
kiberkli's Avatar
QuoteOriginally posted by bertwert Quote
That's how it starts.... at least for me... I sent my K-30 in for repairs and it's been fine since. But check other automatic lenses.
03-11-2016, 11:21 AM   #5
bertwert's Avatar
QuoteOriginally posted by kiberkli Quote
Oh no...
Yep happens with every lens...
03-11-2016, 12:43 PM   #6
NO NO NO.
Get it seen to now, while the camera is still supported. I waited too long to send in my *ist-DL, only to be told they no longer had the necessary parts. FWIW, I found that Ricoh Canada's consumer interface was pretty good - they were reasonably fast getting back to me with the bad news, and they did so as a communication from an actual technician who was willing to discuss the details of the problem rather than just an auto-reply from an unmonitored address.
03-11-2016, 12:49 PM   #7
bertwert's Avatar
QuoteOriginally posted by pathdoc Quote
Luckily I'm still under warranty so I should send it in soon
This is going to be a hard time without my camera while it is being repaired
03-11-2016, 01:34 PM   #8
virusn3t's Avatar
Believe me, is harder when this happens and you must pay for a well recorded problem in this line of cameras K30/50...
03-11-2016, 03:31 PM   #9
Senior Moderator
Parallax's Avatar
You need to look at this in a positive light. Now you have a reason (Okay, so there's a fine line between "reason" and "rationalization") to buy a K-3/K-3II or, if the timing works out, a K-1.
KIDS! Seeesh. They can never see the big picture.
03-11-2016, 03:54 PM   #10
bertwert's Avatar
QuoteOriginally posted by Parallax Quote
But not the money...
03-11-2016, 03:59 PM   #11
Senior Moderator
Parallax's Avatar
Oh, well, there is that.
03-11-2016, 04:03 PM   #12
Oh I'm sure you can afford a full-frame Pentax camera, bertwert... just not the digital variety. Put a few zeroes after the K and the one, and you can take a couple of zeroes off the end of the price...
03-11-2016, 04:15 PM   #13
bertwert's Avatar
So this only happening occasionally...
I presume this means it'll get worse over time?
03-11-2016, 06:32 PM   #14
virusn3t's Avatar
My K30 begins that way, one picture black the rest ok, then three pictures black, then 5-6.... Before sending the camera to repair i put optical preview on the FXbutton to "fake" an aperture movement from a shot, and i need to push and release that button for a few mminutes before the aperture start working again (i can tell when start work properly because i put an aperture like f3.5/5.6 and the lens closes the aperture up to f32 in the "bad shots", when the apwrture didnt close at that aperture i knew the camera was ready to go)
03-11-2016, 06:56 PM   #15
The silver lining is that Takumars ought still to work
camera, dslr, images, photography
K-3 Exposure Button Stuck After Rain Exposure soroush Pentax K-3 13 03-24-2015 09:20 AM
Long exposure shots, ND filters and multi-exposure averaging rrstuff Photographic Technique 17 10-19-2013 12:50 PM
Long exposure / provia 200 : how to know the good exposure compensation ? aurele Pentax Film SLR Discussion 3 02-18-2012 06:58 PM
K10D ccd shake abnormal and maybe some screw inside... daivx Pentax DSLR Discussion 3 05-22-2009 11:04 PM
Rear focusing 16-45 -- abnormal? pingflood Pentax SLR Lens Discussion 2 07-06-2008 08:37 AM
All times are GMT -7. The time now is 03:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
