Originally posted by Tony3d I was just thinking about the ton's of electronics built into a modern day DSLR, and was wondering what the life expectancy of a camera such as the K3-ll would really be? Electronics is one of my hobbies, and one of the most common failures in electronic circuits has to be electrolytic capacitors! Over time they basically dry out and short! I'm sure almost all caps are monolithic surface mount caps in camera's, but I'm pretty sure an electrolytic must be used somewhere in cameras most likely for flash. Maybe I'm wrong.
It's been 6 years since i've got the K-x, 40.000 actuations (i did around 30.000 in the last 3 years).
I've beaten it to death, in sands, humidity, rain, mud, dust, moisture, you name it ! It traveled in various bags, usualy with books, a laptop, keys, climbing gear.
Let's face it, i torture this body way more than it should, and still, it survive quite well. Well, almost.
The outside is polished on the border, i've killed the AF module (AF motor works), i've somehow f**ked the right side of the VF wich is always blurred, the metering can be random sometimes.
But hey, i still takes lots of pictures with it, in full manual
You'll change body far before it will die.
