07-09-2008, 01:59 AM   #1
sand and snow
what setting should I use for pictures on sand and snow and strong back lighted photes on my K100D Super?
07-09-2008, 02:57 AM   #2
ftpaddict's Avatar
I think a slight over-exposure is recommended for snowy conditions, regardless of what camera you use.
07-09-2008, 05:29 AM   #3
alohadave's Avatar
Usually EV+1 to EV+2 is recommended depending on the brightness. Bracketing is useful to make sure you get the correct exposure.
The reasoning is that the lightness of the sand or snow confuses the metering in the camera, and it will try to make the scene darker to make the overall 18%(or 12% depending on who you ask) gray. By setting a positive EV, you are telling the camera to adjust the metering towards the lighter side.
The same works with shooting darker colors. A negative EV will tell the camera to adjust towards the darker side.
07-09-2008, 06:47 AM   #4
thans for the suggestion.Im New to DSLR photography and the Pentax K100D Super is my first camera. the dial on top of the camera on the left has all kind of settings,I mostly us it in the AutoMode. Is there a setting that I should use for sand or snow in addition to EV+1 to EV+2? Thanks Jim
07-09-2008, 07:48 AM   #5
I do not remember if exposure compensation works in Auto mode (do not use it). You can definitely switch to P mode and then adjust exposure. You can also achieve the same thing by using manual (M) mode. You just have to know which way to turn the aperture or shutter. Using EV in P mode might be easier for beginners because it shows as either +1 or -1.
07-09-2008, 07:53 AM   #6
jshurak's Avatar
QuoteOriginally posted by ftpaddict Quote
Yes, this is true and true for the opposite end of the spectrum as well.
Simply, the camera's light meter evaluates everything against medium grey. Its going to underexpose scenes heavily bright white and overexpose scenes heavy black.
So you can't listen to the meter in those situations. Manually dial in over or underexposure in those situations, via dial or ev comp
camera, dslr, photography, sand, snow
Nature sand Taff Post Your Photos! 10 12-14-2009 02:58 AM
Snow or Sand Fl_Gulfer Monthly Photo Contests 0 01-30-2008 01:58 PM
Sand AVANT Monthly Photo Contests 0 01-24-2008 05:59 PM
Let it snow, Let it Snow, Let it F'ing snow Peter Zack Post Your Photos! 21 01-02-2008 08:00 PM
No surf or sand...but plenty of snow. spillway Post Your Photos! 3 01-07-2007 08:17 AM
All times are GMT -7. The time now is 12:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
