Originally posted by stevebrot There is the assumption that RoHS required a thorough redesign of all lenses due to heavy metal content. Of course that assumption is based on a deeper assumption that most (all) lenses were out of compliance or that lead is a common component of traditional optical glass.
Just about all optical glass has lead in it at varying concentrations. Lead makes glass easier to work with when it is molten and makes it less inclined to chip or shatter when it is formed into blanks and ground and shaped into the elements that make up our lenses. RoHs was mostly designed to reduce the ridiculous amounts of lead being used in consumer electronics* - glass makers weren't the principal industry targeted by RoHs. But there are well known cases of glass being made with all kinds of horridly toxic metals in them: radioactive thorium, radioactive lanthanum, cadmium. RoHs sought to encourage wider spread of compliance and stricter limits on the use of those metals.
*electronics for scientific, military and medical use can use as much heavy metal in them as they please, as they are typically low volume devices that require high tolerances that only the use of compounds with heavy metals in their construction can achieve.
