This information is actually being recorded, but that it's makerdata which not-so-current exif readers can't decrypt/understand. The whole EXIF standard is a bit of a scrappy thing - some of the property fields and values are standardised across brands, but then there are also a lot of fields and data which are encrypted and brand-specific. And every EXIF reader is playing catchup trying to understand what these brand specific tags mean.
I typically use an old EXIF Editor called "Exif Pilot" myself and that tells me about 40-50 pieces of EXIF information on a K-3II image but doesn't tell me roll angle or pitch angle etc. But If I use a much more up to date EXIF reader like
http://regex.info/exif.cgi which understands more Pentax-specific tags, I get several 100 bits of info, including roll angle and pitch angle. In other words, the data is there (for K-3ii at least), but it's just that your reader doesn't understand exif tags well enough to spot it. Image below is readout from
It is probably worth your trying that URL to see if your orientation etc is recorded. I don't know which model Pentax started recording this orientation data, maybe it started with K-5 (ie as wombat2go suggests), maybe before.
