03-30-2016, 03:29 AM - 1 Like   #16
I was more impressed that he dropped the camera into a shallow puddle onto pavement.
Well I haven't dunked mine on a puddle but dropped my k-5II on the pavement last saturday evening. My battery grip was scratched including the shutter release button of the camera. My camera still works. Now I believe that Pentax cameras are tough but I do not wish to do it again.
03-30-2016, 06:03 AM   #17
fwcetus's Avatar
QuoteOriginally posted by dosdan Quote
I've been shooting junior athletics & soccer with a K20D, K-5 & K-3 with a DA* 60-250/F4 lens since 2010. In heavy rain the deep lens hood on this lens works well as long as it's not too gusty. However, after 1-2 hrs, with the internal volume change involved in continual zooming in & out, the lens will start to mist up. (At least for me, it does.) You need to get under cover, take the lens off, wipe the rear lens element and pump the zoom in & out a number to times to reduce the amount of moist air trapped inside the lens.
I often use a DA 55-300/4-5.8 WR lens (on a K-3), and, much more often than not, it's racked all the way out to 300mm for shooting. I try to minimize zooming from 55mm (the usual "parking position") out to 300mm and back too often when it's damp/wet or dusty, simply to minimize sucking air in and out too often -- it's better, methinks, under such conditions, to walk around with the lens extended to 300mm between shots, even if it's a bit more awkward to do so.
I also like to use an old Takumar metal lens hood screwed in solidly (sorry - off the top of my head I can't remember exactly which one - it might be for the 135/2.5 and 200/4 (?) - in any event, it's similar to the shape and size of the OEM hood). While the plastic OEM bayonet-mount hood seems reasonably solid when mounted, it has wide air spaces (which are also water spaces) around its base where water can more easily get to the front element, even when just dangling from a neck strap or otherwise aimed downward -- the screw-in Tak hood requires any water that "wants' to get to the front of the lens to have to blow in, or to fall in when the lens is aimed level or higher.
Finally, "take the lens off, wipe the rear lens element and pump the zoom in & out a number to times to reduce the amount of moist air trapped inside the lens" is ~excellent~ advice, and I would just add that it is worth repeating the "pumping" action several times, not just when first getting the lens and body back inside, but every once in a while over the next few hours. [I think it's also worth "airing out" the cam body a bit (even using a blower a few times) before storing it with its body cap (or any lens) on it.]
Just my 2 f-stops worth...
03-30-2016, 10:34 PM - 1 Like   #18
Kameko's Avatar
Why? Someone can deliberately drop their camera and still have it work. Yesterday my (damn) rabbit banged the gate hard enough that my K5ii + FA 400 fell, hitting the ground, pulling the lens mount off and bent it. Is it a matter of deliberate drops only? Or does the universe hate the Easter Bunny?
04-02-2016, 04:45 PM - 1 Like   #19
clawhammer's Avatar
QuoteOriginally posted by Heie Quote
SORRY, WHAT WAS THAT? I CAN'T HEAR YOU OVER THE SOUND OF A YEAR OF DEPLOYED PHOTOJOURNALISM...
-Heie
Well then I stand happily corrected
04-02-2016, 06:22 PM   #20
Heie's Avatar
QuoteOriginally posted by clawhammer Quote
Ha, thanks for having a sense of humor and playing along
-Heie
04-06-2016, 08:06 PM   #21
Kameko's Avatar
Of course it can handle a year in Afghanistan, but give it a minute with the easter bunny....
IPhone 6 Plus  Photo
04-06-2016, 08:23 PM   #22
bertwert's Avatar
QuoteOriginally posted by Kameko Quote
04-07-2016, 12:04 AM   #23
MarkJerling's Avatar
That's a pretty sad looking bunny! So would I be if that was my camera!
addition, camera, dslr, forrest, gear, gump, photography, rain, times, vietnam, water, weather-sealed dslr
How much of a chance do you take buying a used lens? robert Pentax SLR Lens Discussion 45 03-17-2016 12:52 AM
Pentax K30 Picture Leak & Discussion: Weather-sealed intro DSLR LFLee Pentax News and Rumors 1054 05-31-2012 01:12 AM
How much of a difference does weather resistance make? smackythefrog Troubleshooting and Beginner Help 11 03-09-2010 02:17 PM
How much weight can that M42 adapter take? germar Pentax SLR Lens Discussion 7 03-10-2009 07:48 AM
Weather seals, how much can it take? melander Pentax DSLR Discussion 25 10-05-2008 10:34 PM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
