04-01-2016, 04:16 PM   #16
I'd probably pair an older FA 28-105 f/3.5-5.6 (IF) (with hood) or its F series predecessor with the K-S2. You might not be able to get a kit like that, but you can do body and used lens and save quite a bit. While the F/FA 28-105 might not be as wide or as long as the 18-135, it is highly usable as a general purpose walkaround lens. However, being FF glass, you lose out on a bit of wide angle field of view. Since it's not designed for aps-c, the effective FOV of the lens would be considered roughly 42-157.5mm. Still a great lens. As for the K-50 vs K-S2, I love my K-50 to death, but my recommendation is definitely with the K-S2 for its specs and features. Whether or not that body will suffer from the same aperture issue as K-30/K-50 only time will tell.
04-02-2016, 09:36 AM   #17
I own a k-s2 and the only thing I envy a k-50 having is composition adjust. And the money saved.
04-02-2016, 01:29 PM   #18
Personally I like the AA battery option that comes with the K50. It was a deciding factor in my decision to purchase it, though I recognize that may very well be a niche preference amongst Pentaxians.
04-02-2016, 02:34 PM   #19
Des
QuoteOriginally posted by BrAtClIF Quote
Invaluable when you haven't got access to a power source for a long time, or need to do a lot of continuous shooting and haven't time to change batteries, or if you like the camera to have a little extra heft. But otherwise, a couple of spare DLi109 batteries is a lightweight solution (59g v about 120g for 4xAA batteries and adapter) and (even with a spare DC charger) cheaper than an adapter, two sets of Eneloop Pluses and a decent charger.
04-03-2016, 12:47 AM   #20
QuoteOriginally posted by Setter Dog Quote
Hi Folks,
I recently came back to Pentax with a K50 and 55-300 WR. I'm very happy with this combination. For stills, it's hard to beat!
However, I now "need" another lens, almost certainly the 18-135 WR. Knowing the way I am about changing lenses, I will want another body for this lens. Once again, I find myself comparing the merits of the K50 and the KS2. When purchased with the 18-135mm, there is less than $150 difference in price.
Fortunately, the price is not a problem for me, but I note the KS2 is a little heavier,
supposedly has a grip that is not quite as good, is not as comfortable with big lenses, etc,. I like cameras that are fun to use. The vari angle LCD is a nice feature, but not important to me.
Forgetting price, can anyone give me any reasons to buy the KS2 instead of another K50? Maybe the video is a tad better? Any comments appreciated.
Jack
A heavier body will balance a slightly heavier lens better, A lighter body will make the Body-Lens combination front heavy causing pain while holding for prolonged periods.
07-27-2016, 08:26 PM   #21
Weevil's Avatar
The K-S2 is a more modern camera overall. You get better image quality, faster screwdrive AF, more accurate low-light AF, faster live view AF, an improved menu, faster everyday speed, wi-fi, and more processing options. The main disadvantage of the K-S2 is the smaller grip; in other areas I'd consider it a direct upgrade over the K-50.
And the K-S2 has the TAv mode !
07-27-2016, 08:37 PM   #22
QuoteOriginally posted by Weevil Quote
The K-50 has TAv too. Pretty much every Pentax camera launched in past years does, in fact. If it's not on the mode dial, it's activated via M mode with auto ISO on.
07-27-2016, 09:32 PM   #23
Weevil's Avatar
Ho! ok, Thanks for the info...
I did not physically played with those bodies, I just saw that info under this link (Pentax K-S2 vs. Pentax K-50 - Pentax Camera Comparison - PentaxForums.com) I noticed the difference, but did not know more about that feature on the K-50
Actually, I placed a more specific question about that comparison here: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/326743-camera-ne...-100-more.html
camera, dslr, k50, k50 or ks2, ks2, lens, lenses, photography, price, wr
K50 w/18-135mm, Good Choice? Setter Dog Pentax DSLR Discussion 23 02-09-2016 04:40 AM
18 - 135mm WR lens or HD 55 - 300mm WR ? kweekun Pentax SLR Lens Discussion 20 12-28-2015 08:30 PM
Overall size K50 w/18-55 WR? csa Pentax K-30 & K-50 2 09-20-2014 12:13 PM
K30 w/ 18-135mm or K5 w/ 18-55mm AL WR & SMCP-DA 50-200mm WR biscohuffer Pentax DSLR Discussion 8 06-25-2013 08:30 PM
All times are GMT -7. The time now is 08:15 PM. | See also: NikonForums.com, part of our network of photo forums!
