04-07-2016, 11:41 AM   #16
joergens.mi's Avatar
It may not be an absolute measurement od speed , but it is a good comparison between cards on the identical equipment. You can see which card is the fastest in this system, and that is the point i'm interested in.
04-07-2016, 03:10 PM   #17
I just did another test. I did burst of RAW at 1/1000 shutter speed until the buffer filled, then released the button after the next shot and measured the time for the card access light to turn off meaning the data had been written (single card). I repeated this with the two types of card I have. As the only variable is the card write speed it's a reasonable test...obviously it starts writing before the buffer fills, but that only takes a couple of seconds so it's not hugely significant.
The Sandisk Ultra has 20MB/s max theoretical write speed and takes 43s to write the 24 files totalling 652MB - an actual write speed of 15MB/s
The Sandisk Extreme Pro (90MB/s) took 18s ish to write the same data in the same conditions - an actual write speed of 36MB/s
If the Extreme Pro was able to run at full speed it would take only 6s to write.
04-07-2016, 09:37 PM   #18
QuoteOriginally posted by victormeldrew Quote
This fits well to other experiences made by several people, The limiting element is the camera, which delivers a maximum write speed of 36 MB/s.
I'm really interested in the real write speed of the K-1.
I am curious as to how you measure this. Would you care to give a step-by-step description? Steve
We did it the same way as victormeldrew described it, which is fine - as I have written above - for comparative tests - of different cards at the same equipment. I'm using "sandisk extreme 64 GB" and
"Transcend SDXC UHS-I U3 128GB Speicherkarte (95 MB/s Lesen, 60MB/s Schreiben)"
camera, cards, dslr, photography, sd, sd card
Fastest SD Card speed? creative69 Pentax Medium Format 2 11-26-2015 04:04 PM
Fastest SD Card for DSLR Sandmansc Troubleshooting and Beginner Help 7 07-31-2015 05:56 AM
sd card speed for K-3 nicoprod Pentax K-3 11 08-01-2014 05:19 AM
not just the fastest, but most durable sd card slip Troubleshooting and Beginner Help 26 01-21-2013 10:19 AM
Who makes the fastest/best quality SD card for the money? ronin67 Pentax Camera and Field Accessories 2 12-25-2009 01:17 AM
All times are GMT -7. The time now is 08:05 PM. | See also: NikonForums.com, part of our network of photo forums!
