Originally posted by stevebrot
I edited my last post. See my correction.
As for an indication of over/under, EC is available in both Av and M modes. In addition, a viewfinder EV scale is available in M mode on flaghip models by using the optical preview feature.* I will have to research your K-S2 to see if it supports similar.
* Only visible if the optical viewfinder level feature is turned OFF.
Originally posted by rbelyell
wow steve THAT WORKED! if i set the RAW button as you suggested and press it in M mode, i can manually set the SS and/or aperture to whatever i want and i see the effect on the EV bar! excellent! that is really a big deal for me. thank you so much! i hope i can repay the favor sometime.
I use older manual lenses almost (but not) exclusively on my K10 and K5IIs. I leave the camera in manual mode, and use the optical preview feature with the EV scale to help with exposure settings.
Same as I did with the needle EV scale in the viewfinder on my film SLR.
Easy Squeezy
