Let me tell you about something that Pentax does better than Sony mirrorless. With my K3 (and i assume follow models), one clicks on the +/- button and you're looking at a -5 to +5 scale and you can see a needle like indicator swing back and forth across the scale as you move the camera across the scene. Simple - ergonomic.
With my Sony premium mirrorless, you get a dial on the top where one can crank in from -3 to+3 in exp comp. (In Manual mode, you get only -2 to +2 scale) With the dial, the EVF scale will only show you the current exp comp setting from -3 to +3. If the camera cannot adjust to the exp comp setting of zero or whatever one has cranked in on the dial, then the indicators blink. It doesn't tell you where you are in exposure, you have to keep trying adjustments till it comes within range and the blinking stops. Thats so not "ergonomic" compared to the Pentax.
So one may ask, where is the promised -5 to +5? If you go into deep menu diving, you can find an alternate exp comp setting process and it has the -5 to +5. It also lets one know that if you want exp comp on Manual, one needs to have the iso set to AUTO.
So the Pentax exp comp process is so simple and straight forward, the Sony exp comp process is complicated and its taken me 2 weeks to figure out its intricacies. Will it work - yes, but i miss the digital scale that Pentax has which lets me survey the scene for dark and light areas. Sony does have a live miniature histogram that shows up in the frame as an optional display mode. thats pretty cool and sort of makes up for the lack of a digital exposure scale, but not quite.
Do ergonomics matter?
Yeah they do.
