Originally posted by Adam Great info! I'm sure the ExifTool will eventually be updated to support that tag. Phil pushes out updates pretty often.
A few months ago I had a discussion with Phil Harvey on that topic, because ExifTool did not find SRFocalLength for my K-S1.
Phil told me that apparently no one has been specifically looking for SRFocalLength. And I have not found the time to look for it.
Therefore, any help is welcome.
PS: It seems that the bodies that have no known SRFocalLength are all the bodies with AA filter simulation.
---------- Post added 04-29-16 at 07:55 PM ----------
Originally posted by stevebrot Pentax:LensData:LensFocalLength is 8-bit integer.
Yes, and with a very tricky encoding. 6 bits are used to encode an integer value, and the two other bits are used to encode an exponent.
The complete formula is '10*($val>>2) * 4**(($val&0x03)-2)' which apparenly was reverse engineered by an ExifTool contributor named Jens Duttke.
By studying various lenses, you may also notice that every zoom takes exactly 16 different values of LensFocalLength.
