05-14-2016, 10:27 AM   #1
jab2980's Avatar
Damaged shooting mode dial effect water resistance?
Hey there. The shooting mode dial on my K5II was damaged in a way that the plate on top (which has the mode icons) is somewhat bent and separated from the dial itself. Does anyone know if this will effect the water resistance of the camera (I'm not able to see enough to determine if this leads to the innards)? If so, I suppose I can try to cover it with gaffer tape when out in the rain. Thanks!
05-14-2016, 11:16 AM   #2
Could you post a picture? If any internal component has been displaced, it's likely that the seal has been too.
05-16-2016, 10:19 AM   #3
jab2980's Avatar
Thanks for the reply, Adam. It's obvious that water can get in there, I'm just not sure if the damaged disc is critical to weather proofing, or if the dial has internal seals as well.Thanks!
05-16-2016, 11:32 AM   #4
It's possible that the important weather sealing actually takes place on the bottom where the knob meets the body, but without seeing the knob removed it's hard to know for sure. If there's evidence of weather sealing on the button atop the knob as well, then you may have a problem.
05-16-2016, 11:42 AM   #5
I'd guess that the rubber seal underneath the dial is fine, but if water could accumulate inside the it, it could possibly eventually break through the seal.
05-16-2016, 01:42 PM   #6
jab2980's Avatar
On to searching for the best gap filling superglue! Thanks guys
05-24-2016, 09:54 AM   #7
QuoteOriginally posted by jab2980 Quote
SUper glue may also run inti the camera. It is typically quite hard and may crack easily here.
Have it fixed properly of use Dukctape.
camera, dslr, effect, effect water, mode, mode dial effect, photography, water
How to test water resistance of our DSLR without risk LeDave Pentax DSLR Discussion 36 09-09-2015 07:45 AM
Water damaged DA* 16-50 robr7 Troubleshooting and Beginner Help 7 07-11-2014 07:36 AM
K-01+DA* 50-135 water-damaged: Any chance of recovery? Alizarine Troubleshooting and Beginner Help 9 07-08-2014 07:51 AM
Resistance to water guillermovilas Pentax SLR Lens Discussion 4 05-13-2007 12:17 AM
All times are GMT -7. The time now is 08:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
