05-15-2016, 04:04 AM   #1
MichaelErlewine's Avatar
Smallest Extension Ring for the K Series Cameras
What is the thinnest (most narrow) extension ring that fits the K-series cameras, and what is is brand and where can I find one, please?
05-15-2016, 05:07 AM   #2
They usually come in sets of three: small (8-12mm); medium (20-25mm) large (30-35mm).
The trick is to find a PKA set with contacts - but by coincidence I have a set spare.....
05-15-2016, 05:22 AM   #3
Not a Number's Avatar
The Pentax Auto Extension Tube K and Extension Tube K have the smallest ring at 12mm and 9.5mm, respectively. The Auto tubes have the aperture control lever so you can use the green button or DOF optical preview for metering while focusing wide open. The Tube K does not have a lever so you have to manually stop down after focusing at wide open.
Both are long out of production so you have to try the used market.
As noted above third party set may have A, KAF, KAF2 contacts and screw drive. The A and KAF (without power zoom contacts) are on the used market. Those with the power zoom/SDM contacts (Kooka and others) can be found through various vendors (try Amazon). Note the tolerances on these latter tubes is shoddy so interfacing with the camera electronics can be finicky.
PENTAX Auto Extension Tube Set K reviews - Pentax Camera Accessory Review Database
PENTAX Manual Extension Tube Set K reviews - Pentax Camera Accessory Review Database
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/317762...-any-good.html
https://www.pentaxforums.com/forums/16-pentax-news-rumors/264093-new-auto-ext...-q-mounts.html
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/285873...-any-good.html
05-15-2016, 10:56 AM   #4
pacerr's Avatar
Depending on your use you may be best served with a $12 set of close-up filters. No light loss and you retain all auto lens functions. If flat-plane issues are critical you'll need a dedicated macro lens.
To the extent that optical issues are of concern with single element, un-coated 'filters' try a step-up ring to two sizes over your lens filter to avoid the outer edges of the CU glass and be cautious of lighting that might cause flare.
Yeah, yeah, I know what 'everyone' says about 'em - they're inexpensive so try 'em for yourself anyway. I've got a cabinet full'a rings and bellows I've used for 'work stuff' but most often select the filters for hand-held use in the field and have never regretted it. Cropping often serves as well unless camera position/perspective is critical.
camera, cameras, dslr, extension, photography
PENTAX auto extension ring K set 30535 Buckeye Pentax SLR Lens Discussion 6 02-08-2014 07:47 PM
Tripod ring for K-series 300mm f4.0 sawtooth235 Pentax SLR Lens Discussion 4 06-18-2012 04:24 AM
Any compact cameras with manual focus ring on the lens? ChopperCharles Pentax Compact Cameras 9 03-25-2011 01:26 PM
Smallest bag possible for Pentax K-X Silverkarn Pentax Camera and Field Accessories 11 08-25-2010 10:46 AM
New fimware for Samsung GX series Cameras BarneyCG Pentax DSLR Discussion 2 04-10-2007 04:05 AM
All times are GMT -7. The time now is 08:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
