05-26-2016, 12:59 PM   #1
Does anyone make this? (rubber O ring for body)
I'm talking about an 'O' ring that looks like it would fit between a lens mount and the body. I recently purchased a Sigma 18-300mm, that so far is excellent(tight on the zoom function), but it looks like you can put an O ring between the lens and the body. This may not make it waterproof, but looks like it would help. has anyone ever done this? thanks
05-26-2016, 01:03 PM   #2
Not sure where you live, but and hardware store should have a a collection of o-rings.
05-26-2016, 01:27 PM   #3
TomTom's Avatar
QuoteOriginally posted by fstop18 Quote
Are you seeing light leaks? The reason I ask is that I have a Tokina that looks a little "unfinished" but it works well with no problems.
This is not a great pic but you can see the shiny silver showing while the lens is mounted.
05-26-2016, 01:34 PM   #4
narual's Avatar
You could use a rubber band or O ring to help to keep excess dust out, but if you want to keep water out, well, you need a WR lens and body in the first place.
There was a kickstarter for a gasket a while back for Canon, but the reviews for it were pretty spectacularly lousy and again, it only really would have helped with dust, not water
https://www.kickstarter.com/projects/77243737/dust-donuttm-add-a-weather-sea...he-mount-of-an
05-26-2016, 10:24 PM   #5
JimmyDranox's Avatar
I also had a Sigma lens which had a gap, or better say, a bigger distance on the bayonet. It was working well, but the lens had a little play. I have used a very thin sheet of metal to cover the gap.
05-26-2016, 11:52 PM   #6
p38arover's Avatar
QuoteOriginally posted by gaweidert Quote
The best place (at least in Oz) to get O-rings is at a bearing supplier.
05-27-2016, 08:00 AM   #7
thanks folks, mine does have the 'unfinished look' like TomTom mentioned. There is really no mechanical problem, just for the look.
05-28-2016, 08:03 AM   #8
I went to a marine/auto parts store & found a package of various O rings. One of them seems to be a good fit and does the job I want. (a real custom job ehh?) thanks again
body, camera, dslr, lens, photography
Does anyone make this? Auzzie-Phoenix Pentax Camera and Field Accessories 13 05-06-2015 12:28 AM
Nature This heat would make anyone hopping mad 😀 Sorver Post Your Photos! 2 10-29-2014 12:41 AM
Does this make sense for an SDM expansion tube? philbaum Pentax SLR Lens Discussion 14 12-15-2011 10:09 PM
Does anyone else make cameras? Tony3d Pentax DSLR Discussion 17 02-20-2011 05:56 AM
Does anyone know what this lens is for? cyy47 Troubleshooting and Beginner Help 7 07-15-2009 10:16 PM
All times are GMT -7. The time now is 09:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
