Originally posted by shortphaselabs I appreciate all the help here!
I've managed a way to make it work but I'm weighing the benefit. It would work to use a simple relay or double switch to trigger the camera and flash simultaneously but independently. I have most of the necessary gear and know-how to make this happen. The education of it is the goal but there is a concept behind it all which might make it all worth while but it's becoming much more complicated than a simple camera setting.
If you have the know how to insert a relay on the flash trigger then a variable capacitor on the coil pin would create a variable delay. You would want to isolate the camera hotshoe from a relay coil though as the coil breakdown would likely blow the camera circuit....a chunky diode should be fine but I wouldn't want to stick my neck out with your kit!
