Originally posted by zoolander I had this conversation a long time ago. If you have a lens that tops out at 45 lines per millimeter on crop, that Line widths per millimeter (LW/PH) translate on a 36 x 24mm sensor, versus 24 x 15mm crop sensor, and equates to an increase in 1/3rd of resolution. 36mm divided by 45 lines is gonna be more than 24mm divided by 45 lines. Thats the concept.
Some actual numbers from IR...
16 MP APS_c tested out at 2100 lw/ph
24 MP APS-c tested out at 2700 lw/ph/
36 MP FF (K-1) tested out at 3500 lw/ph.
20 MP FF Canon 6D test at 2400 lw/ph
The difference between 24 MP APS-c and 24 MP FF is about 100 lw/ph or 2800 for 24 MP FF. Functionally identical. If you are to break that down into lines per mm, the 24 MP APS-c is way more.
In the case of a 20 MP FF (6D) 24 MP APS_c gives you a couple hundred more lw/ph plus it's smaller sensorr, so in terms of line per mm, it serious kicks the 6D's butt. Or to summarize, Pixel Density is way more important than format in determining lw/ph,
The king has to be something like the Panasonic FZ 2500 which gets 2500 lw/ph on a one inch sensor. 9mm c 12mm.
SO get this, the Panasonic in good light gets 2500 distinct lines out of a 9mm deep sensor. That's 277 distinct lines per mm. That's some serious resolution.
I think the error in your thought is thinking there are lenses that top out at 45 lines per mm.
An APS-c sensor has a depth of 16mm. So on a K5 2100 lw/ph divided by 16 gives you 133 line per mm.
A K-3 179 line per mm.
Using the same lens you're getting an extra 63 lines by increasing your pixel density.
Lets take the crappiest lens we know. The 18-55 kit lens. At 10MP, it produces max of about 2100 lw/ph (not the same measurement as the above.No one knows why klaus' numbers are so ,much higher than everyone else, it's one of those mysteries of the universe.) hopefully they are consistent,) At 16 MP that grows to 2604 lw/ph. Using the cheapest lens you can find, it's not the lens that limits the resolution, it's the pixel density. Hence the whole part about the lens producing 45mm across various sensors is in error. There is not a lens I know of that doesn't produce a higher lw/ph count with a denser sensor. And part of that will be that the smaller the sensor, the more of the sharpest part of the lens it uses.
If you don't look at real tests done with real lenses and sensors, it's easy to make this kind mistake.
If looking at older lens tests, many were done in paired line per mm, which would mean you have to cut the numbers in half to compare apples to apples. But you're still looking at 140 paired line per mm for the Panasonic, even if that's true. The resolution folks get out of even small sensor small lens cameras in digital leaves film in the dust. A lens producing 45 lines per mmm on digital would be piece of junk.
People who formulate this kind of intellectual notion without any kind of real world input, often screw up really bad. It may sound logical, but that in no way suggests it has anything to do with the real world. There are few theories in earth so simple someone somewhere can't take it, apply it incorrectly, and produce ridiculous results, and then claim science proves them right. It's especially common in photo blogs.The big question should be, who checked your work? Even real scientists have checks and balances.
