07-16-2008, 09:45 PM   #1
Damn Brit
Guest
Last firmware update for K10d
I never uploaded the last firmware update for the K10d, should I?
Gary
07-16-2008, 09:56 PM   #2
Ash
Community Manager
Ash's Avatar
You might need it for those SDM lenses you're buying soon....
07-17-2008, 12:51 AM   #3
Zebooka's Avatar
Yepp. with 1.30 you'll get:
Changes to V1.30 Correspond to PENTAX DA lens which built-in supersonic motor (SDM System)
Changes to V1.20 Correspond to PENTAX REMOTE Assistant 3
Changes to V1.11 Correspond to development in the RAW data camera when multiple exposing.
When built-in flash is used the luminescence control by the trailing-shutter-curtain sync was corrected.
Changes to V1.10 The following function has been added in version 1.10
Wireless control of external flash through built-in flash.
Instantly return to centre AF point by one push of button in AF select mode.
Possible to change ISO setting by dial at TV/AV mode.
ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
Green button function in M mode is available at TAv mode (Hyper manual).
AV and TV switch by dial at P mode.
Instant return to the default value by green button at strobe light compensation.
The following contents have been corrected.
In rare case, vertical stripe at long time exposure.
Released “B exposure” and show battery empty sign when using B mode.
07-17-2008, 04:39 AM   #4
Serpiente's Avatar
is it really needed? how can I chack my version? and how can I install when I have for example version 1.00 and not the latest before 1.30?
greetings
07-17-2008, 06:06 AM   #5
Jodokast96's Avatar
You can check it by holding the Menu button when turning the camera on. You don't need 1.2 to upgrade to 1.3. Is it needed? That's up to you.
07-17-2008, 03:46 PM   #6
Serpiente's Avatar
QuoteOriginally posted by Jodokast96 Quote
Ok.. So I dont need the previous updates.. That was why I had doubts about installing..
thanks
camera, dslr, firmware, k10d, photography
Firmware update for K10D master49 Pentax DSLR Discussion 2 02-11-2009 10:57 AM
K10d firmware update question Bokeh Pentax DSLR Discussion 14 05-24-2008 06:56 PM
How to update firmware in K10D? FLASH Pentax DSLR Discussion 8 11-13-2007 09:08 PM
k10d firmware update button Pentax DSLR Discussion 4 05-08-2007 08:09 AM
K10d Firmware Update greenbeen128 Pentax News and Rumors 74 05-07-2007 08:11 AM
All times are GMT -7. The time now is 03:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
