07-17-2008, 10:05 AM   #1
Noise Reduction - K10D
Hi
I have a couple of rookie questions.
How long does an exposure have to be before the Noise Exposure kicks in on the K10D?
What circumstances would be good to switch it off?
I'm going to be doing some night photography and wondered what effect it would have in switching it off. Last time I did some on long exposures it took a while before the NR finished.
Thanks, Paul
07-17-2008, 10:09 AM   #2
Canada_Rockies's Avatar
QuoteOriginally posted by paolo g Quote
Hi
Thanks, Paul
I have not been using noise reduction in camera at all to avoid the recording delay from the dark image. I am operating under the assumption that I can use software in post processing to eliminate the noise if I have to.
07-17-2008, 10:13 AM   #3
When noise reduction is turned on, any shots will cause K10D to perform the noise reduction step. The time it take to do noise reduction is equal to time of the exposure, so basically exposure time x2 for the time of a shot. A couple of situations I can think of when you want to turn nosie reduction off, one is when trying to take picture of firework, as the exposure time is in the seconds, you don't want to wait any time to be ready for the next shot. Two is when you want to use post processing to do your only nosie reduction. I have not had the needs to turn off nosie reduction myself yet.
07-17-2008, 10:16 AM   #4
Jodokast96's Avatar
On long exposures, it will take about twice as long as what the exposure is. I just did this last week, but can't remember for sure, but it is somewhere between 3 and 10 seconds.
07-19-2008, 01:30 AM   #5
The Dark Frame NR kicks in on anything longer than a second. It doubles the actual time taken to process the shot before the camera is ready to shoot again.
You can switch it off and do a few trials to see if you can see a difference in your shots. The main purpose is to map hot pixels and cancel them out on your shots.
It is difficult to apply a hot pixel NR process in post processing but the software called Qimage allows you to capture a blank shot and use this as a dark frame subtraction process on your images in the Jpeg mode.
Another method to reduce noise is to use the double exposure function and take the same shot at least 3 times. The random noise tends to cancel itself and reduces the visible noise in your final shot but I have noticed that edges become a little softer. Also, this method does not save any time at all but is useful in bright light conditions where your short exposures will not be an issue.
This method is useful for high ISO shots where the result will be a bit grainy.
Have fun!
camera, dslr, exposure, k10d, noise, noise reduction, photography
Pentax K10D long exposure noise reduction when shooting RAW? Robert S Donovan Pentax DSLR Discussion 30 08-19-2013 11:42 AM
Noise reduction richardsmith Digital Processing, Software, and Printing 4 10-26-2009 06:01 PM
Do you do noise reduction? alehel Digital Processing, Software, and Printing 39 04-12-2009 05:14 AM
K10D body noise reduction... allill Pentax DSLR Discussion 1 12-16-2008 03:30 PM
K10D Noise Reduction photog Pentax DSLR Discussion 1 10-31-2007 02:11 PM
All times are GMT -7. The time now is 10:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
