06-19-2016, 08:12 AM   #16
UncleVanya's Avatar
I'm not sure dual image stabilization works better today. The tests done by a couple of people on the newer Panasonic bodies showed that the ois by itself outperformed dual ois/is. This will likely change over time.
06-21-2016, 01:38 AM   #17
Fogel70's Avatar
The advantage of having both is that they can take care of different types och camera shake. FI OIS compensate for pitch/yaw, and SR take care of X/Y and roll.
To get them both to work together on same type of motion might not add anything.
Its usually not the amount of motion that limit image stabilization, it is the accuracy of the motion that is the limit, and if using two mechanisms for compensating the same motion, it risk making the motion less accurate.
06-21-2016, 01:49 AM   #18
What also is important is that all Systems are limited ob the lower end. Shutter times longer than 1/4 of a second See difficult, Even though I regularly shoot 24mm ff at 1/2 second handheld, that often requires 2-3 tries.
camera, dslr, lengths, pentax shake reduction, photography
Shake Reduction Question sibyrnes Pentax DSLR Discussion 6 06-02-2016 01:40 PM
Shake Reduction question beginnerbee Troubleshooting and Beginner Help 3 06-26-2013 06:40 PM
Shake reduction question PentaxKX-2011 Troubleshooting and Beginner Help 7 01-23-2011 12:09 PM
K-x shake reduction question Coby Video and Pentax HDSLRs 2 01-06-2010 09:21 AM
Shake Reduction Question Workingdog Pentax DSLR Discussion 25 01-03-2008 11:31 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
