07-18-2008, 01:03 PM   #1
atnbirdie's Avatar
Replacement Lens Hood for 18-55mm Kit Lens?
The lens hood on my 18-55mm kit lens no longer locks in place. It appears some part of the plastic retaining ringhas worn down so it twists on, but doesn't lock on. Thus, it tends to fall off if it brushes up against something (e.g., when I put it down, or when slung over my shoulder).
Does anyone know where/if I can get a replacement? Alternatively, is there a way to make it 'lock' again?
Thanks,
07-18-2008, 01:06 PM   #2
Jodokast96's Avatar
PentaxWebstore 52mm Lens Hood PH-RBA
07-18-2008, 01:11 PM   #3
rogerstg's Avatar
QuoteOriginally posted by atnbirdie Quote
I've had some success building up minute amounts of worn plastic using superglue, allowing it to build onto itself if needed. It dries pretty hard.
07-19-2008, 01:59 PM   #4
atnbirdie's Avatar
Jodocast96- Thanks for the link. However, I think I'll try Roger's fix before dropping $32+ on a lens hood.
Thanks all,
07-19-2008, 07:14 PM   #5
atnbirdie's Avatar
Replacement Lens Hood-Super Glue
Roger, thanks for the super glue tip. It worked like a charm. I put a thin layer on the surface of all the locking tabs, let it dry, and the hood is nice and snug now.
07-20-2008, 06:28 AM   #6
rogerstg's Avatar
I'm glad it worked for you.
07-20-2008, 02:21 PM   #7
Big Dave's Avatar
Steve,
You can buy another 18-55 off market place for $50 with a hood. Remove the hood and resell it for $40 less hood or keep it for a spare.
Dave
Thanks,
07-20-2008, 03:19 PM   #8
check ebay, I just replaced one for my K10d
18-55mm, 18-55mm kit, camera, dslr, hood, hood for 18-55mm, kit, lens, photography, replacement, replacement lens hood
M42 Super Takumar 35mm 3.5 lens hood replacement. Image Eye Pentax SLR Lens Discussion 9 06-24-2010 07:38 PM
Replacement for 18-55mm II kit lens catalina Pentax SLR Lens Discussion 11 04-25-2010 03:58 PM
Replacement lens hood has a little issue.. Javaslinger Pentax SLR Lens Discussion 6 01-25-2010 12:11 PM
Replacement for 18-55 stock lens hood? Javaslinger Pentax SLR Lens Discussion 1 11-16-2009 07:19 PM
Lens hood for the kit 18-55mm? cinaibur Pentax Camera and Field Accessories 15 03-06-2009 08:04 AM
All times are GMT -7. The time now is 11:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
