07-04-2016, 03:34 PM   #1
Pentax 10d focus tuning
I have just got done doing a physical focus tune on my Pentax 10d .I tuned it to work with 50 mm lens as it was severely back focusing. Here is how, remove the bottom and when the camera is upside down the are thee hexagonal screws,go with the front one towards the lens mount /Adjust it either clockwise or counterclockwise.Just remember how many revolutions you did and in what direction in case you need to un-. due it,.
07-04-2016, 04:04 PM   #2
BigMackCam's Avatar
Did you try adjusting the AF fine tuning from the hidden service menu first, as per this thread?: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/3158-k10d-servic...af-adjust.html
I can only assume adjusting that screw is mechanically moving sensor closer to / further away from the mount, in which case even if you *think* you have moved the screw back to its original position, the chances of returning the sensor to *exactly* the original position are pretty slim... so you risk throwing all your other lenses into back or front focus...
I could be wrong, of course.
(EDIT: thread moved from General Talk to Pentax DSLR Discussion)
07-04-2016, 04:18 PM   #3
Yes I know about the debug menu and fine tuning it, but it was back focusing on every lens ,So in the service manual they say to calibrate it using a 50 mm lens. So I did and it worked like a charm.
07-04-2016, 04:20 PM   #4
BigMackCam's Avatar
OK. Cool
07-04-2016, 04:24 PM   #5
OK. Cool
Yeah got sick of going into debug to make it right, the results are marvelous .
07-04-2016, 07:36 PM   #6
ChristianRock's Avatar
I need to do that with mine...
Edit: turns out my AF is fine, the F 50 1.7 focus well (as expected) unless it misses focus... I had to get it to test the K10D since the K10D pretty much only uses manual lenses, and the Tokina 19-35 3.5-4.5 which has a wider focus area, so it's not really a good reference. What I have a problem with, apparently, is my diopter - to use my manual lenses I have to turn the diopter almost all the way to the right. I have no idea if that would be fixable... the problem is that the viewfinder image gets smaller as you go to the right, and focusing gets harder, so an O-ME53 might be needed...
focus, lens, pentax, pentax 10d focus, tune
Pentax K-10D for beginner? mikecomua Pentax DSLR Discussion 13 08-16-2015 08:32 AM
For Sale - Sold: Pentax K-10D with DA 16-45mm f/4 Lens manishved Sold Items 4 04-21-2015 07:00 AM
Front / Back Focus Tuning eccs19 Pentax SLR Lens Discussion 5 08-09-2012 08:43 AM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 13 11-19-2011 11:32 PM
Bad focus on K-10D. flashcactus Troubleshooting and Beginner Help 2 08-28-2011 09:03 AM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
