Originally posted by goatsNdonkey So it sounds like, if someone in a rush does some batch post processing, letting their PP program teak a few things automatically, they might not actually be taking as much control over the final image as someone with a K-1 who is being diligent about using all of the control over in-camera processing that is available. Hmmmm? Interesting. And as pepperberryfarm points out, those settings can be tweaked as one shoots.
True, careful post processing done image by image after the exposure has greater potential, but does every PPer use the highest level of care with each image all of the time? Could careful control over in-camera jpegs sometimes get better results than PPed images where one just goes through the motions? I'm not calling for debate on these two questions as much as suggesting that people who shoot both ways some of the time be honest with themselves...and then consider sharing those reflections.
It is a worflow thing. Depending of your workflow, you may prefer working with one or the other or a mix.
For me and I speak for my workflow, not saying it is universal I work frow RAWs only.
Here is my workflow:
Quote: I usually start by previewing the photos fast on a viewer and to keep only the best, most interresting shots. i can do that several time.
Then I try to select a color profile/rendering that overall suit well the shooting session and what I want to express. The basis for that is a DxO film pack simulation. I work it on a few representative on the set, until I get the rendering I want and apply it to all photos.
I then review each photo one by one, adapt the things a bit if needed, work on horizon/perspective and check if a reframing would not improve the picture. i continue to drop photos on the go when I didn't manage to decide the one to keep before.
At that point I export all images and look at them in slide slow, trying to see if something should be corrected and they all look good. I make a few minor corrections, export again and I am done.
For all I said, basically the picture being taken as RAW or Jpeg is irrelevant to the process. All pictures get the same workflow anyway. But I know that I have more information to work with RAW. I can usually get bette high iso, tweak the white balence or overall rendering more. I can get back the burned highlights or push the shadows.
If I just want the jpeg without thinking I can directly export all of them without doing anything or applying one the profile I created in the past.
To me it is more work, more complication to think RAW or JPEG this time or even to compare RAWs and JPEGs to see if one is better. I just take one format, always raw and I am done with it.
Furthermore, the K3 ergonimics make it quite easy to mess up the JPEG settings when trying to move the selected AF point. It can happen I end up with some weird settings due to that. In raw I don't care as it is not even taken into account.
But that just me. People will do JPEG only or mix for their own reasons. For me RAW only is just much simpler. I don't have to think about it and I am done.
