I've noticed this a couple of times before, but this is a pretty extreme example... I took this photo with my K-3 a couple of days ago. It was sunny, and there was sunlight shining directly onto our cat. Photo taken with the DA*60-250 wide open at f/4. If you look at the whiskers, and the fur to the upper left of the image, there are areas that a multi-coloured - red, magenta, yellow, green, blue etc. If I look really carefully, I can make this out at 1:2 and even 1:3 reproduction. The crops below are at 1:1 and 2:1 to show the effect at its worst. The photo is a raw DNG file viewed in Lightroom 6, but the effect is visible in DCU5 also.
Has anyone come across this effect before? Is it a K-3 or Pentax thing, or a general issue with digital sensors - or something else?
EDIT: Hang on... is this moiré I'm seeing? I can remove it using Lightroom's Moiré slider, it seems!
