07-11-2016, 06:47 AM   #1
JinDesu's Avatar
Pentax does quite well in noise performance (if we didn't know that already!)
Comparing the Sensor Noise of Top Cameras
For each camera he tests, Davey shoots 3 different exposures at 1 second, 30 seconds, and 300 seconds (i.e. 5 minutes). Other factors are held constant: no light is entering the viewfinder, the environment is room temperature, ISO is set at 3200, NR is off, and RAW capture at max bits per channel.
The guy's website himself: The Sensor Noise DB. – Brendan Davey Photography
Looks like the k-5 and the k-1 do quite well as the length of time is increased. Especially at the 5 min/300s mark.
07-11-2016, 07:05 AM   #2
I'm impressed. The longer you go, the better the K-5 gets compared to the rest. By the end, it's in second place (compared to quite a few newer cameras, too). That must have been one hell of a good sensor/algorithm package they put into it, and I will be truly sorry when mine finally packs it in.
Interesting to see the K-1 trailing it all the way, even though it comes in just one place behind it at the 5 minute mark.
Of course with Astrotracer, the K-1 almost certainly will be used on a fairly regular basis for MUCH more than five minutes. It would be interesting to see whether it catches up and surpasses all the competitors if the test were extended to ten or fifteen minutes. Perhaps we should ask him for an extended test on those grounds alone?
07-11-2016, 12:35 PM   #3
QuoteOriginally posted by pathdoc Quote
Not really, since the astrotracer is limited to 5 minutes. But on the other hand, the tracer is probably one of the reasons that Pentax have focus on doing well in long exposures.
07-11-2016, 04:39 PM   #4
JinDesu's Avatar
It also goes to show that the k-1 is no slouch. Unfortunately my k-3 doesn't do as well, but it's reasonable in the 30s range.
07-12-2016, 04:58 AM   #5
QuoteOriginally posted by JinDesu Quote
I thought the same until I looked up the prices of the competitors with similar noise performance, especially once a half decent lens is attached. Even better considering the feature set of my K3II compared to those bodies.
I've never had any practical problem with noise though, even where it is fairly evident it's quite easy to remove.
Save
07-12-2016, 06:23 AM   #6
JinDesu's Avatar
QuoteOriginally posted by victormeldrew Quote
Save
Yeah, I upgraded from a k-x to a k-3, so the benefits outweigh any perceived weakness in noise performance compared to having gone to a k-5. I adore my k-3
07-12-2016, 06:35 AM   #7
newmikey's Avatar
I actually have had no issues getting extremely decent ISO12800 results out of my K-5 IIs, provided I use an external, self-profiling noise reduction program such as NeatImage. I do not often have to go that deep, any darker and I cannot even see what I'm trying to shoot!
07-12-2016, 04:18 PM   #8
audiobomber's Avatar
When comparing these images, it is important to note that a 300 x 300 pixel crops favour sensors with lower pixel density. Comparing an APS-C 24mp body with 16mp, both at 300 pixels square, is not a level playing field.
camera, dslr, noise, noise performance, photography, sensor
Why didn't I know this??? Zephos Photographic Technique 20 03-02-2016 12:08 PM
Can't Believe I Didn't Know This (Feeling Stupid) OrangeKx General Photography 31 12-22-2014 11:15 AM
Now That We Didn't Get All We Wanted With The K-3... tabl10s Photographic Industry and Professionals 50 10-24-2013 03:04 PM
Public disapproval - Just in case you didn't know it..... stevewig General Talk 17 08-06-2011 08:13 PM
Ever have the feeling you didn't quite fit in? NaClH2O Post Your Photos! 8 01-22-2011 10:36 AM
All times are GMT -7. The time now is 03:10 AM. | See also: NikonForums.com, part of our network of photo forums!
