07-21-2008, 02:18 PM   #1
should I be concerned ?
Hi guys, I'm into the second week with my new K10D, there's a whole bunch of stuff to learn but up to now it's looking good.
But is this anything to worry about, when I look through the viewfinder it seems to be covered in very fine dots. Is the view finder glass just textured ? There is one large speck though that can be clearly seen.
When I take the lens off the dotty texture and the dot is still there so the lens has nothing to do with it.
Am I just seeing the viewfinder OR am I actually seeing what goes to the sensor ??
hope this make sense. BARCUD
07-21-2008, 02:32 PM   #2
RBellavance's Avatar
The focusing screen does have a texture. It is most easily seen against a bright background (eg. blue sky). A larger dot, however, might be dust or something of the sort that landed on it.
The focusing screen can be removed and cleaned, but be aware that it is very fragile. Unless the speck is very bothersome, I would leave it alone.
07-21-2008, 02:32 PM   #3
I took a look through my K10D and I don't see anything like what you describe. My understanding is that on the K10D you do NOT see the image from the sensor (I think the K20D has this and is called live view). I am going to guess that your mirror--not the sensor-- has dust on it.
07-21-2008, 04:39 PM   #4
You can't see sensor dust through your viewfinder. Does it kind of look like frosted glass or ground glass? If so, it's just the texture of the focusing screen. If the dots are big black specks, then it's probably dust. Use something like a rocket blower to gently clean it. Don't touch the glass.
07-21-2008, 06:26 PM   #5
willis's Avatar
Take off your polarized sunglasses.
07-21-2008, 07:07 PM   #6
rfortson's Avatar
It's the matte finish on the view screen. This is a common question among new users.
Occasionally, you may see a spec of dust on the view screen. It can be annoying, but doesn't affect picture quality at all.
07-21-2008, 07:08 PM   #7
rfortson's Avatar
QuoteOriginally posted by rrsell Quote
Live view is seen on the back LCD. He's referring to the matte finish on the viewfinder focus screen. It's on your K10D, too, but it's very subtle. It's supposed to aid in manual focusing, but I don't think it does much good. You can change focus screens, though.
07-21-2008, 07:09 PM   #8
Wheatfield's Avatar
QuoteOriginally posted by BARCUD Quote
You are seeing the texture of the screen (it's called a "groundglass" for a reason, even though they are now plastic). You can probably see some lines as well. The larger speck is probably a bit of dust. Don't worry about it, it won't hurt anything where it is.
You can use a blower from a blower brush to try to blow it off. I would NOT use a compressed gas blower (Dust-Off, et al) unless you are really sure of what you are doing. It is very easy to blow the shutter (literally) when the mirror is down, and damage it.
07-22-2008, 12:52 AM   #9
that's reassuring
many thanks guys that's a mystery solved. The viewfinder looks just how you described it. There is one speck but I'll leave it where it is I think. I could blow it off but who knows where it might end up !?
great forum
BARCUD
07-22-2008, 01:46 PM   #10
rfortson's Avatar
great forum
BARCUD
If you do try to blow that spec off, make sure to use a Rocket Blower or some other bulb type blower that you'd use to clean your sensor. However, instead of locking up the mirror as you'd do to clean the sensor, try a few blasts of air with the mirror down. That was the only way I could get rid of a pesky spec on my viewfinder screen.
camera, dslr, lens, photography, viewfinder
I'm concerned about glasses jbander Pentax Medium Format 10 10-06-2010 09:31 AM
I'm still concerned with the dust alphalt Pentax DSLR Discussion 26 02-23-2010 06:01 PM
Paranoid or legimately concerned? T_MB Photographic Technique 18 09-02-2009 06:49 AM
To all concerned with K20D/Hot Pixel Issue codiac2600 Pentax DSLR Discussion 170 06-24-2008 05:28 AM
Recommendation needed for tonight, taking pics of speakers and concerned about WB shaolin95 Pentax DSLR Discussion 3 02-09-2008 01:11 PM
All times are GMT -7. The time now is 03:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
