Originally posted by butangmucat Do I need to short the contacts for IBIS and focus confirmation to work?
IBIS does not care what lens you have mounted. You can even use it
without a lens (not recommended, but you can see the sensor move inside the camera). It depends on the focal length that you will manually input when you turn on the camera and a manual lens is mounted. Input the same number as is written on the lens, or the nearest wider number. No equivalence or any other silly calculations. The only time you want to input a different number from what is written is if you cannot select the exact same number, if you are using a zoom lens (where you can only input one number at a time and camera does not know what zoom level you are using. Usually best to choose the widest number that you will be using, or the one you will be using the most), or in some macro situations (some tests have shown that due to the extreme magnification in macro you can actually turn SR up a bit and it will deliver better results, not worse). Note that SR can degrade image quality if you input a higher number, or it can undercompensate if you input a lower number. Note also that you should not use SR with in-lens stabilization - only use one at a time, as using both can cause conflicts.
Focus confirmation is different mechanism. I think the centre point focus confirmation works without contacts or any other info, you just might have to press the focus button and select the right options.
You only need to short the contacts for things like Catch in focus and maybe automatic aperture stopping down (there are some threads about this, but I never bothered delving into it). CiF needs to have AF contacts shortened (not necessarily lens ID) and AF on camera enabled (while AF on lens is disabled or just unavailable). Check manual for details, as some things have changed from camera to camera over the years
Originally posted by lytrytyr So I wonder if Mitakon is doing the same thing. This could account for a poor reputation in China that might not be reflected overseas.
That sales tactic was very common, but I have seen even Mitakon reviews by westerners, and they were not very positive. There was even a thread on these forums about the 35mm and 85mm Mitakon lenses. They cost a little less than the Samyang, but have less automation and are far softer wide open.
