08-30-2016, 06:53 AM   #1
problem Adjusting auto focus on k20d
After adj focus (menu>custom setting>35. AF Adjustment 2> 2 ON), not only does the adjustment not happen but neither does half press shutter nor AF button cause focu to happen. Camera is set to AF.S. Lens is set to A. Everything functioned before I tried to adjust focus because a whole series of pics were slightly out of focus. I have not tried Ricoh help desk yet. I'm hoping someone here has also had and solved this issue. Thanks for any help and any sympathy.
Rich
08-30-2016, 07:07 AM   #2
Which lens? Only works reliably with Pentax as the body has to recognise the lens.
Did you follow the steps in the Operation Manual?
You've said what didn't happen, but what did? None of what you describe is related to AF Adjustment, so could you have inadvertently set some other adjust?
adjustment, af, auto focus, camera, dslr, focus, help, k20d adjust auto focus, photography
Micro adjusting focus - How have you got on with it? Chris Giles Pentax Medium Format 5 04-08-2015 09:32 AM
K-3, auto focus problem ladybug36 Troubleshooting and Beginner Help 9 12-05-2014 07:31 PM
Adjusting the fine focus on K-x... GibbyTheMole Troubleshooting and Beginner Help 7 03-06-2014 10:32 AM
Problem adjusting f-stop on 50mm prime Unregistered Visitors' Center 9 11-21-2011 10:27 PM
Focus adjusting on GX-10 ITW Pentax DSLR Discussion 4 12-27-2010 07:08 PM
All times are GMT -7. The time now is 03:40 PM. | See also: NikonForums.com, part of our network of photo forums!
