09-08-2016, 04:44 AM   #31
Rob,
Thanks for the response and confirming my notion that the dcrawps four file output is only useful for quality review or a last ditch effort to save the shot. I usually take a conventional shot along with the PSR as a fallback. I wish that the new dial on K 1 had an entry for PSR as going to the back screen is a pain. Also wish Image Sync had option for PSR as I'd prefer not to mess with tripod area once setup.
RONC
09-08-2016, 06:01 AM   #32
QuoteOriginally posted by rechmbrs Quote
Rob,
RONC
Mm, I use fn2 button for the Ps, so it only takes one click of a button to switch it on/off.
09-09-2016, 09:59 AM   #33
I discovered that in Lr in addition to validating the checksum and integrity of the DNGs (at least those with said checksum) you can also generate the checksum. Use the "Update DNG preview and metadata" command (a manual command to write metadata to file doesn't seem to generate a checksum (prudent, since it would be slow). Not sure that using the command in Lr to update is much different than "converting" to DNG; seems about the same speed.
09-09-2016, 10:44 AM   #34
QuoteOriginally posted by awscreo Quote
Thanks for mentioning use of the fn2. I set it up for PSR. Too many options for my old mind.
RONC
09-09-2016, 01:39 PM   #35
QuoteOriginally posted by Oakland Rob Quote
Based on the EXIF, it appears to be a conversion to an Adobe-generated DNG with the hash stored in the NewRawImageDigest tag.
adobe software, camera, compression, dng, dslr, files, image, images, lightroom, motion, pef, photography, pixel, post, ps, shot, size
PEF or DNG? rlatjsrud Troubleshooting and Beginner Help 10 03-19-2016 06:01 PM
RAW-- PEF vs DNG... difference? CEWren Pentax K-5 9 07-23-2011 10:34 PM
Difference between DNG and PEF? ismaelg Pentax DSLR Discussion 15 06-06-2011 01:16 PM
Pentax/Honeywell...Is there any difference? pickles Pentax SLR Lens Discussion 8 05-29-2010 09:12 AM
Difference between PEF and DNG formats john_mantz Pentax DSLR Discussion 6 09-25-2007 11:24 AM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, part of our network of photo forums!
