Originally posted by hooper Q1-the k1 is the first full frame dslr from pentax.Does that mean what you see is what you get in the photograph?
When I use my LX camera what you see is what you get.
What do you mean by "what you see is what you get", more exactly?
Framing? It will be what you see in the viewfinder; but that's true of APS-C bodies, too (because their viewfinders are adapted to the format - note that their viewfinders are a far cry of that of an old manual camera). Something else?
Originally posted by hooper Q2-Why have anything other than full-frame on a camera?
Price. FF cameras are expensive, most people prefer to spend less - and APS-C offers good quality at an affordable price (they can get even lower than $500).
Size can also be an important factor (the K-S1/K-S2/K-70 sure are small!)
Originally posted by hooper Q3-What is an APS-C body ?
A camera whose sensor is about 23.5 x 15.6 mm (slightly less for Canon)
Originally posted by hooper Q4-What are the benefits of crop mode on the dslr.
For the K-1:
- eliminating the need to crop later, if using an APS-C only lens (you'd have to crop out the ugly vignetting - if present)
- smaller files (by itself, not enough to use it IMO)
- higher performance (max frame rate raised to ~6.5fps)
It's actually not such a big deal, and of course you can shoot in "full frame" mode and crop later, on the PC.
