Show Printable Version 19 Likes Search this Thread
09-07-2016, 10:55 AM   #16
Battery Protection
So, how do ~you~ protect your D-LI90's ?
A little piece of gaffers tape over the end on mine.
This is also how they want them protected when flying.
Chris
09-07-2016, 12:39 PM - 1 Like   #17
The battery contacts are recessed so 2 batteries cannot short circuit each other. I store my extra batteries in a camera bag pocket and keep metal objects out of that pocket.
09-07-2016, 12:46 PM   #18
QuoteOriginally posted by c57d Quote
As noted above in the original post, "I have found that two D-LI90's can be squeezed into a slightly deformed D-LI90 cardboard box (ideally with their business ends reversed in the box), but the box is a bit flimsy, and this is not an ideal solution." That's why I've been looking for something better (and I appreciate all of the answers, everyone - Thanks).
I just ordered a few of these small plastic boxes from Amazon, which I hope will work reasonably well - for 3 - for 5 - for 10
I am hoping they will fit the D-LI90 form factor reasonably well -- I am estimating that the length and height may work well, although the width of the container may be a bit on the sloppy slide. (?)
09-07-2016, 12:50 PM - 1 Like   #19
Pioneer's Avatar
I use a nifty, 4 pocket, battery carrier when I am packing them around. If I am only carrying one or two then I use the same plastic caps that work so nicely on my older batteries for the K10D. When I'm not carrying them then I just set them on the shelf...totally unprotected.
I thought of using rubbers but did not want to explain that to the grandkids.
Oh well.
09-07-2016, 01:04 PM   #20
My D-Li90s are either in camera or clicked into the DBC90 charger.
I have never taken a loose battery or chargers on a trip because I take film cameras.
I took the Oly M43 to Grand Canyon along with the RB67 and the Oly ran out of battery half way through the trip.
I was using the M43 for indoor and family photos that I did not anticipate!
09-07-2016, 01:17 PM   #21
aleonx3's Avatar
I have 4 extra DLI90 batteries... each stored in a small zip-locked plastic bag. I put sticker label inside each marked with date when it was last charged. I always have one (or two) of those batteries in my camera bag.
09-07-2016, 01:20 PM   #22
By the way, what was the latest/greatest Pentax dslr with pentaprism that used 4 of AA ?
Like my ist ds but newer.
09-07-2016, 01:32 PM   #23
QuoteOriginally posted by wombat2go Quote
The K200D ? The K-x ? (Maybe the latest (last?) - dunno about greatest.)
Yes, I also had a *ist DS (my first DSLR), which used either 4 x 1.5 Volt AA cells (alkaline or rechargeable) or 2 x CR-3V Lithium packs. [I found the two CR-3V's pretty convenient, since the alkaline AA's didn't last too long, and the rechargeable AA's I had didn't like to hold their charge for very long -- the CR-3V's held their charge very well and provided enough juice for lotsa pix.]
09-07-2016, 01:40 PM   #24
QuoteOriginally posted by fwcetus Quote
Thanks fw
I got months/charge out of a set of rechargeable Ray-O Vacs on the ist ds, but that is probably because I used it more like a film camera.
rather than how we tend to use a camera these days.
I have a 2 week trip soon to Australia/Taiwan , one thought is to take the ist ds and Pentax MX, plus the -M 40mm pancake plus the -M 28mm
That is a compact kit and spare batteries and chargers and spare film are not required, and AA batteries are available anywhere.
09-07-2016, 01:59 PM   #25
MJKoski's Avatar
I store them in empty matchbox. Just pop open the box and there you go - fresh battery. Used batteries go into their own boxes marked with fitting label.
09-07-2016, 02:54 PM   #26
K-50 has the option 4x AAs or Li
09-07-2016, 04:42 PM   #27
QuoteOriginally posted by surfar Quote
I'm not at all familiar with the K-50, but didn't it require some sort of an external battery pack to use the "4x AAs or Li" ?
09-07-2016, 05:08 PM   #28
Otis Memorial Pentaxian
clackers's Avatar
Nuh, you could buy an adapter that sits *inside* the compartment - I got one for my K-30, worked quite well.
09-07-2016, 05:18 PM   #29
Heh-heh (<sheepish_grin>) -- well, I did say that "I'm not at all familiar with the K-50". .
Actually, having owned, for DSLR's, only the *ist DS, the K20D, and the K-3, I should probably keep my mouth shut about all the others...
09-07-2016, 05:56 PM   #30
reh321's Avatar
No, when the K-S2 came out, I asked several times before I partially understood why the K-30/50 "trick" didn't work for the K-S2.
Now that I own a K-30, I finally understand it.
On the theory that "a picture is worth a thousand words", here is 2000 words of explanation
batteries, battery, bit, box, camera, cap, contacts, d-li50, d-li90, dslr, k-5, photography, plastic, solution
Which batteries do you hate, and why (AA NiMH vs. D-LI90 vs. D-LI109)? fredralphfred Pentax DSLR Discussion 32 01-30-2022 05:52 AM
(How) Do you keep track of your charged and uncharged batteries? BigMackCam General Photography 26 05-31-2017 02:58 PM
How do you store your lenses rjm007 Pentax SLR Lens Discussion 55 11-01-2015 12:50 PM
How do you store your photos and what do you store? Conqueror General Photography 22 05-05-2015 09:55 PM
How do you store your camera & lens in the bag / backpack? Prakticant Pentax Camera and Field Accessories 5 04-15-2015 04:29 AM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
